    File Syncing for a long time with M5Could
    FACES Kit
    6.3k
    • A
      Arissa
      When I used M5Could for my M5Stack Faces, the IDE shows the comment, "File Syscing...", for a long time. Thus I pressed button A and power button to reset as the IDE mentioned "(If there is no response for a long time, press and hold the button A and press the reset button to enter safe mode and try again)", however, still shows the comment, "File Syscing...". How can I deal this trouble? Should I try another day?
      • m5-docsM
        m5-docs @Arissa
        @arissa We suggest you program FACES with flow.m5stack.com
        We are developing and promoting this programming platform instead of M5Cloud.
        Here's the getting started documentation.
        https://docs.m5stack.com/#/en/quick_start/m5core/m5stack_core_get_started_MicroPython
        M5Stack documentation URL
        • A
          Arissa @m5-docs
          @watson Thank you for the reply. I will try with "flow.m5stack.com" or offline.
