    FS.h missing
    4 Posts 2 Posters 16.5k Views 1 Watching
      dpcons
      Downloaded m5stack library and examples from GitHub. Also downloaded and installed "Arduino-esp master". Tried to compile 'FactoryTest.ino". Got following error.
      C:\Users\dpcon\Documents\Arduino\libraries\M5Stack-master\src/M5Stack.h:94:16: fatal error: FS.h: No such file or directory
      also got same error on 'Display.ino'
      Any suggestions. Shouldn't FS.h be part of the package??
      • JJJ Offline
        JJ @dpcons
        @dpcons
        Hey dpcons,
        I'm guessing you do not have this directory in your system:
        C:/Users/[YOUR_USER_NAME]/Documents/Arduino/hardware/espressif/esp32
        FS.h should reside in:
        C:\Users\YOUR_USER_NAME\Documents\Arduino\hardware\espressif\esp32\libraries\FS\src
        If your using windows the following link shows how to get this installed:
        https://github.com/m5stack/m5stack-board-support/blob/master/doc/windows.md
        FS.h should install as part of this. FactoryTest should work then.
          dpcons
          Thanks JimiT,
          You were indeed correct. I discovered the instructions for windows later last night and finished the install correctly. The download links were somewhat misleading. I'm now good to go. Thanks again for the response.
          • JJJ Offline
            JJ @dpcons
            @dpcons No problem. Enjoy !
