đŸ€–Have you ever tried Chat.M5Stack.com before asking??😎
    Cardputer Wake-up clock with wav sound from SD
    1 Posts 1 Posters 323 Views
      malrain
      // Bird song wake-up for Cardputer
      // string must be translated
      // time zone idem
      // SSID and Pass must be changed if you nuse one ssid #define MAX_ROUTERS 6 -> #define MAX_ROUTERS 1
      // wav file must be put on SDcard of Cardputer
      #include <ArduinoJson.h>
      #include <LittleFS.h>
      #include <M5Cardputer.h>
      #include <M5GFX.h>
      #include <WiFi.h>
      #include <WiFiUdp.h>
      #include <NTPClient.h>
      #include <SD.h>
      #include <SPI.h>
      #include <HTTPClient.h>
      #include <Wire.h>
      #include <esp_log.h>
      #include <TimeLib.h>
      #include <Timezone.h>
      TimeChangeRule* tcr;
      // to be adjusted according to your criteria
      #define SCREEN_TIMEOUT 90000
      #define MOVING_DISPLAY_DURATION 3000
      #define TRIGGER_HOUR 6
      #define WAV_FILENAME "/2380.wav"
      // RÚgles pour l'heure d'été/d'hiver en Europe (UTC+1/UTC+2)
      TimeChangeRule CEST = { "CEST", Last, Sun, Mar, 2, 120 }; // UTC+2
      TimeChangeRule CET = { "CET", Last, Sun, Oct, 3, 60 }; // UTC+1
      Timezone CE(CEST, CET);
      int TRIGGER_MINUTE = 25;
      // --- Variables globales ---
      float batteryLevel;
      unsigned long lastActivityTime = 0;
      unsigned long lastSyncMinute = 9999;
      static unsigned long lastNotificationTime = 0;
      const unsigned long NOTIFICATION_DELAY = 5000;
      int lastConnectedRouterIndex = -1;
      int contrast = 33;
      int volume = 22;
      bool screenOn = true;
      bool isWaitingForInput = false;
      bool lowPowerMode = false;
      bool screenInitDone = false;
      static constexpr const char* files[] = {
      "/2380.wav",
      static constexpr const size_t buf_num = 3;
      static constexpr const size_t buf_size = 1024;
      static uint8_t wav_data[buf_num][buf_size];
      struct attribute((packed)) wav_header_t {
      char RIFF[4];
      uint32_t chunk_size;
      char WAVEfmt[8];
      uint32_t fmt_chunk_size;
      uint16_t audiofmt;
      uint16_t channel;
      uint32_t sample_rate;
      uint32_t byte_per_sec;
      uint16_t block_size;
      uint16_t bit_per_sample;
      struct attribute((packed)) sub_chunk_t {
      char identifier[4];
      uint8_t data[1];
      struct Router {
      char ssid[32];
      char password[32];
      Router routers[MAX_ROUTERS];
      int routerCount = 0;
      // --- Variables affichage ---
      String TxtEnTete = "Bird-Alarm ";
      String TxtCorps = "";
      String TxtPied = "";
      String TxtPiedII = "";
      String data = "> ";
      M5Canvas canvas(&M5Cardputer.Display);
      // --- Variables NTP ---
      const char* ntpServer = "pool.ntp.org";
      const long utcOffsetSeconds = 0; // UTC
      WiFiUDP ntpUDP;
      NTPClient timeClient(ntpUDP, ntpServer, utcOffsetSeconds);
      // --- Variables alarme ---
      SemaphoreHandle_t resourceMutex = NULL;
      TaskHandle_t audioTaskHandle = NULL;
      volatile bool audioRequested = false;
      volatile bool audioPlaying = false;
      volatile bool triggeredToday = false;
      static bool playSdWav(const char* filename) {
      File file = SD.open(filename);
      wav_header_t wav_header;
      file.read((uint8_t*)&wav_header, sizeof(wav_header_t));
      // Vérifier la validité du fichier
      if (memcmp(wav_header.RIFF, "RIFF", 4) || memcmp(wav_header.WAVEfmt, "WAVEfmt ", 8) || wav_header.audiofmt != 1 || wav_header.bit_per_sample < 8 || wav_header.bit_per_sample > 16 || wav_header.channel == 0 || wav_header.channel > 2) {
      file.close();
      Serial.println("[playSdWav] Invalid WAV file!");
      return false;
      file.seek(offsetof(wav_header_t, audiofmt) + wav_header.fmt_chunk_size);
      sub_chunk_t sub_chunk;
      file.read((uint8_t*)&sub_chunk, 8);
      while (memcmp(sub_chunk.identifier, "data", 4)) {
      file.seek(sub_chunk.chunk_size, SeekCur);
      bool flg_16bit = (wav_header.bit_per_sample >> 4);
      int32_t data_len = sub_chunk.chunk_size;
      size_t idx = 0;
      M5Cardputer.Speaker.begin();
      M5Cardputer.Speaker.setVolume(volume);
      while (data_len > 0) {
      size_t len = data_len < buf_size ? data_len : buf_size;
      len = file.read(wav_data[idx], len);
      data_len -= len;
      if (flg_16bit) {
        M5Cardputer.Speaker.playRaw((const int16_t*)wav_data[idx], len >> 1, wav_header.sample_rate, wav_header.channel > 1, 1, false);
      } else {
        M5Cardputer.Speaker.playRaw((const uint8_t*)wav_data[idx], len, wav_header.sample_rate, wav_header.channel > 1, 1, false);
      idx = idx < (buf_num - 1) ? idx + 1 : 0;
      M5Cardputer.Speaker.end();
      file.close();
      return true;
      void EnTete() {
      ClearEnTete();
      M5.Display.setCursor(5, 2);
      M5.Display.setFont(&fonts::FreeMono9pt7b);
      M5.Display.print(TxtEnTete);
      batteryLevel = M5.Power.getBatteryLevel();
      drawBattery(200, 5, batteryLevel);
      M5.Display.drawLine(0, 19, M5.Display.width(), 19, YELLOW);
      M5.Display.drawLine(0, 20, M5.Display.width(), 20, DARKGREY);
      M5.Display.drawLine(0, 21, M5.Display.width(), 21, TFT_ORANGE);
      void ClearEnTete() {
      M5.Display.setTextColor(WHITE, BLACK);
      void Corps() {
      ClearCorps();
      M5.Display.setTextSize(1);
      M5.Display.setFont(&fonts::FreeMonoOblique9pt7b);
      int largeurTexte = TxtCorps.length() * 10;
      int x = (M5.Display.width() - largeurTexte) / 2;
      M5.Display.setCursor(x, 25);
      M5.Display.print(TxtCorps);
      void ClearCorps() {
      M5.Display.fillRect(0, 22, 240, 91, BLACK);
      void Pied() {
      ClearPied();
      M5.Display.setTextColor(LIGHTGREY, BLACK);
      M5.Display.setCursor(20, 107);
      M5.Display.print(TxtPied);
      void ClearPied() {
      M5.Display.fillRect(0, 107, 240, 14, BLACK);
      void PiedII() {
      ClearPiedII();
      M5.Display.drawLine(0, 116, M5.Display.width(), 116, YELLOW);
      char buffer[20];
      snprintf(buffer, sizeof(buffer), " Wake-up @ %02dh%02dm | In: %s", TRIGGER_HOUR, TRIGGER_MINUTE, getTimeUntilAlarm().c_str());
      TxtPiedII = buffer;
      M5.Display.setCursor(3, 120);
      M5.Display.print(TxtPiedII);
      void ClearPiedII() {
      M5.Display.fillRect(0, 120, 240, 14, BLACK);
      void drawBattery(int x, int y, float percentage) {
      int width = 30;
      int height = 11;
      int terminalWidth = 2;
      uint16_t color = (percentage > 70) ? BLUE : (percentage > 30) ? YELLOW
      : RED;
      M5.Display.drawRect(x, y, width, height, WHITE);
      M5.Display.fillRect(x + width, y + (height / 3), terminalWidth, height / 3, WHITE);
      int chargeWidth = (int)((percentage / 100.0) * (width - 2));
      M5.Display.fillRect(x + 1, y + 1, chargeWidth, height - 2, color);
      void drawProgressBar(int percentage) {
      int barWidth = 180;
      int barHeight = 10;
      int x = 20;
      int y = 50;
      M5.Display.fillRect(x, y, barWidth, barHeight, BLACK);
      M5.Display.drawRect(x, y, barWidth, barHeight, WHITE);
      int fillWidth = (percentage * barWidth) / 100;
      M5.Display.fillRect(x + 1, y + 1, fillWidth, barHeight - 2, GREEN);
      M5.Display.setCursor(x + barWidth + 5, y);
      M5.Display.printf("%d%%", percentage);
      void connectToStrongestWiFi() {
      TxtCorps = " ";
      Corps();
      M5.Display.setCursor(10, 26);
      M5.Display.println("Scanning Wi-Fi...");
      drawProgressBar(0);
      int numNetworks = WiFi.scanNetworks();
      if (numNetworks <= 0) {
      ClearCorps();
      M5.Display.setTextColor(YELLOW, BLACK);
      M5.Display.setCursor(10, 40);
      M5.Display.println("No Wi-Fi found");
      return;
      for (int i = 0; i <= 100; i += 5) {
      drawProgressBar(i);
      delay(28);
      struct Network {
      String ssid;
      int rssi;
      Network networks[numNetworks];
      for (int i = 0; i < numNetworks; i++) {
      networks[i].ssid = WiFi.SSID(i);
      networks[i].rssi = WiFi.RSSI(i);
      for (int i = 0; i < numNetworks - 1; i++) {
      for (int j = i + 1; j < numNetworks; j++) {
      if (networks[i].rssi < networks[j].rssi) {
      Network temp = networks[i];
      networks[i] = networks[j];
      networks[j] = temp;
      TxtCorps = "SSID found (" + String(numNetworks) + "):\n";
      for (int i = 0; i < min(4, numNetworks); i++) {
      TxtCorps += String(i + 1) + ". " + networks[i].ssid + "\n";
      delay(9);
      Corps();
      for (int n = 0; n < numNetworks; n++) {
      String candidateSSID = networks[n].ssid;
      int foundIndex = -1;
      for (int i = 0; i < routerCount; i++) {
        if (String(routers[i].ssid) == candidateSSID) {
          foundIndex = i;
          break;
      if (foundIndex == -1) {
        continue;
      ClearCorps();
      M5.Display.println("Connecting to:");
      M5.Display.setCursor(10, 46);
      M5.Display.setTextColor(SKYBLUE, BLACK);
      M5.Display.println(routers[foundIndex].ssid);
      // Démarrer la connexion
      WiFi.begin(routers[foundIndex].ssid, routers[foundIndex].password);
      unsigned long start = millis();
      bool connected = false;
      while (millis() - start < 10000) {
        delay(194);
        M5.Display.print(".");
        if (WiFi.status() == WL_CONNECTED) {
          connected = true;
          break;
      ClearCorps();
      if (connected) {
        M5.Display.setCursor(10, 66);
        M5.Display.setTextColor(GREEN, BLACK);
        M5.Display.println("Connected @ ");
        M5.Display.setCursor(10, 86);
        M5.Display.print("IP: ");
        M5.Display.println(WiFi.localIP());
        lastConnectedRouterIndex = foundIndex;
        return;
      } else {
        M5.Display.setTextColor(RED, BLACK);
        M5.Display.println("Connection failed");
        delay(1940);
        ClearCorps();
      // Aucun réseau connu trouvé ou aucune connexion réussie
      M5.Display.println("No SSID found");
      void audioTask(void* param) {
      (void)param;
      while (true) {
      if (!audioRequested) {
      vTaskDelay(pdMS_TO_TICKS(200));
      continue;
      xSemaphoreTake(resourceMutex, portMAX_DELAY);
      audioPlaying = true;
      Serial.println("[AudioTask] Playing WAV file...");
      if (!playSdWav(WAV_FILENAME)) {
        M5.Display.println("Playback failed!");
      } else {
        M5.Display.println("Alarm ended !");
      xSemaphoreGive(resourceMutex);
      String Clavier(String TxtClavier) {
      M5Cardputer.update();
      data = TxtClavier + "> ";
      M5.Display.drawString(data, 3, 120);
      unsigned long startTime = millis();
      const unsigned long TIMEOUT = 30000;
      while (millis() - startTime < TIMEOUT) {
      if (M5Cardputer.Keyboard.isChange() && M5Cardputer.Keyboard.isPressed()) {
      Keyboard_Class::KeysState status = M5Cardputer.Keyboard.keysState();
        for (auto i : status.word) {
          data += i;
        if (status.del && data.length() > (TxtClavier.length() + 2)) {
          data.remove(data.length() - 1);
        if (status.enter) {
          data.remove(0, TxtClavier.length() + 2);
          String result = data;
          data = "";
          return result;
      delay(10);
      return "";
      void saveSettingsToLittleFS() {
      DynamicJsonDocument doc(256);
      doc["contrast"] = contrast;
      doc["volume"] = volume;
      doc["minutes"] = TRIGGER_MINUTE;
      File file = LittleFS.open("/settings.json", "w");
      if (!file) {
      Serial.println("Échec sauvegarde sur LittleFS.");
      return;
      serializeJson(doc, file);
      file.close();
      Serial.println("[LittleFS] ParamÚtres sauvegardés :");
      Serial.print(" - Contraste: ");
      Serial.println(contrast);
      Serial.print(" - Volume: ");
      Serial.println(volume);
      Serial.print(" - Minutes de réveil: ");
      Serial.println(TRIGGER_MINUTE);
      void handleButtonA() {
      if (!isWaitingForInput && M5Cardputer.BtnA.wasPressed()) {
      isWaitingForInput = true;
      ClearCorps();
      M5.Display.setCursor(10, 27);
      M5.Display.println("1. Contrast 0-255");
      M5.Display.setCursor(10, 44);
      M5.Display.println("2. Volume.  0-255");
      M5.Display.setCursor(10, 61);
      M5.Display.println("3. Test WAV");
      M5.Display.setCursor(10, 78);
      M5.Display.println("4. Rv:  6h 0-59m.");
      M5.Display.setCursor(10, 95);
      M5.Display.println("CR = Cancel");
      String choice = Clavier("Selection ");
      choice.trim();
      if (choice == "1") {
        ClearCorps();
        M5.Display.setCursor(10, 30);
        M5.Display.println("Contrast  " + String(contrast));
        M5.Display.setCursor(10, 50);
        M5.Display.println("Input   0 -> 255");
        M5.Display.setCursor(10, 90);
        M5.Display.println("CR => Cancel");
        String contrastStr = Clavier("Contrast: ");
        if (contrastStr.length() > 0) {
          bool isNumeric = true;
          for (int i = 0; i < contrastStr.length(); i++) {
            if (!isdigit(contrastStr.charAt(i))) {
              isNumeric = false;
              break;
          if (isNumeric) {
            int newContrast = contrastStr.toInt();
            if (newContrast >= 0 && newContrast <= 255) {
              contrast = newContrast;
              M5.Display.setBrightness(contrast);
              saveSettingsToLittleFS();
              M5.Display.println("Updated !      ");
              delay(1000);
            } else {
              M5.Display.println("Out of range !  ");
              delay(1000);
          } else {
            M5.Display.println("Wrong input !   ");
            delay(1000);
        } else {
          M5.Display.println("Canceled !      ");
          delay(1000);
      } else if (choice == "2") {
        ClearCorps();
        M5.Display.println("Volume actuel: " + String(M5Cardputer.Speaker.getVolume()));
        String volumeStr = Clavier("Volume: ");
        if (volumeStr.length() > 0) {
          for (int i = 0; i < volumeStr.length(); i++) {
            if (!isdigit(volumeStr.charAt(i))) {
              isNumeric = false;
              break;
          if (isNumeric) {
            int inputVolume = volumeStr.toInt();
            if (inputVolume >= 0 && inputVolume <= 255) {
              volume = inputVolume;
              delay(1000);
            } else {
              delay(1000);
          } else {
            delay(1000);
        } else {
          delay(1000);
      } else if (choice == "3") {
        ClearCorps();
        M5.Display.println("Test WAV file...");
        M5.Display.println("Playing: " + String(WAV_FILENAME));
        if (SD.exists(WAV_FILENAME)) {
          audioRequested = true;
        } else {
          M5.Display.setCursor(10, 70);
          M5.Display.println("WAV not found !  ");
          delay(1500);
      } else if (choice == "4") {
        int newMinutes;
        if (newMinutes >= 0 && newMinutes <= 59) {
          TRIGGER_MINUTE = newMinutes;
          PiedII();
        ClearCorps();
        char buffer[20];
        snprintf(buffer, sizeof(buffer), "Wake-up @ %02dh %02dm", TRIGGER_HOUR, TRIGGER_MINUTE);
        M5.Display.println(buffer);
        M5.Display.println("Input   00' -> 59'");
        String minutesStr = Clavier("Minutes: ");
        if (minutesStr.length() > 0) {
          for (int i = 0; i < minutesStr.length(); i++) {
            if (!isdigit(minutesStr.charAt(i))) {
              isNumeric = false;
              break;
          if (isNumeric) {
            int newMinutes = minutesStr.toInt();
              delay(1000);
            } else {
              M5.Display.println("Out of range !");
              delay(1000);
          } else {
            delay(1000);
        } else {
          delay(1000);
      Corps();
      Pied();
      PiedII();
      void turnScreenOn() {
      if (lowPowerMode || !screenOn) {
      M5.Display.clear();
      EnTete();
      Corps();
      Pied();
      PiedII();
      screenOn = true;
      lastActivityTime = millis();
      void turnScreenToLowPower() {
      if (!lowPowerMode) {
      M5.Display.setBrightness(5);
      lowPowerMode = true;
      void checkScreenTimeout() {
      if (millis() - lastActivityTime > SCREEN_TIMEOUT) {
      turnScreenToLowPower();
      String getTimeUntilAlarm() {
      timeClient.update();
      time_t utc = timeClient.getEpochTime();
      time_t local = CE.toLocal(utc, &tcr);
      int currentHour = hour(local);
      int currentMinute = minute(local);
      int currentSecond = second(local);
      int alarmHour = TRIGGER_HOUR;
      int alarmMinute = TRIGGER_MINUTE;
      int hoursUntilAlarm = alarmHour - currentHour;
      int minutesUntilAlarm = alarmMinute - currentMinute;
      int secondsUntilAlarm = 0 - currentSecond;
      if (hoursUntilAlarm < 0) {
      hoursUntilAlarm += 24;
      if (minutesUntilAlarm < 0) {
      minutesUntilAlarm += 60;
      hoursUntilAlarm--;
      if (secondsUntilAlarm < 0) {
      secondsUntilAlarm += 60;
      minutesUntilAlarm--;
      minutesUntilAlarm = 0;
      char timeStr[20];
      snprintf(timeStr, sizeof(timeStr), "%02dh%02dm", hoursUntilAlarm, minutesUntilAlarm);
      return String(timeStr);
      TxtPiedII = " Alarm in: " + getTimeUntilAlarm();
      PiedII();
      void updateDisplay() {
      if (!screenOn) return;
      int hh = hour(local);
      int mm = minute(local);
      int ss = second(local);
      int currentDay = day(local);
      int currentMonth = month(local);
      int currentYear = year(local);
      M5.Display.fillRect(0, 22, 240, 54, BLACK);
      char timeBuf[16];
      snprintf(timeBuf, sizeof(timeBuf), "%02d:%02d:%02d", hh, mm, ss);
      M5.Display.setFont(&fonts::FreeSansBold18pt7b);
      int tw = M5.Display.textWidth(timeBuf);
      int tx = (M5.Display.width() - tw) / 2;
      M5.Display.setCursor(tx, 25);
      M5.Display.print(timeBuf);
      char dateBuf[24];
      snprintf(dateBuf, sizeof(dateBuf), "%02d/%02d/%04d", currentDay, currentMonth, currentYear);
      int dw = M5.Display.textWidth(dateBuf);
      int dx = (M5.Display.width() - dw) / 2;
      M5.Display.setCursor(dx, 58);
      M5.Display.print(dateBuf);
      M5.Display.setCursor(2, 76);
      M5.Display.print("Wi-Fi ");
      M5.Display.setCursor(69, 76);
      M5.Display.println(WiFi.SSID());
      M5.Display.setCursor(2, 96);
      M5.Display.print("IP ");
      M5.Display.setCursor(69, 96);
      } else {
      M5.Display.println("No Wifi");
      void loadSettingsFromLittleFS() {
      if (!LittleFS.exists("/settings.json")) {
      Serial.println("Fichier settings.json introuvable.");
      return;
      File file = LittleFS.open("/settings.json", "r");
      if (!file) {
      Serial.println("Échec ouverture fichier settings.json.");
      return;
      DeserializationError err = deserializeJson(doc, file);
      file.close();
      if (err) {
      Serial.println("Erreur parsing JSON (settings).");
      return;
      if (doc.containsKey("contrast")) {
      contrast = doc["contrast"];
      Serial.print("[LittleFS] Contraste chargé: ");
      if (doc.containsKey("volume")) {
      volume = doc["volume"];
      Serial.print("[LittleFS] Volume chargé: ");
      if (doc.containsKey("minutes")) {
      TRIGGER_MINUTE = doc["minutes"];
      Serial.print("[LittleFS] Minutes de réveil chargées: ");
      void loadDefaultRouters() {
      routerCount = 5;
      routers[0] = { "SSID1", "Pass1" };
      routers[1] = { "SSID2", "Pass2" };
      routers[2] = { "SSID3", "Pass3" };
      routers[3] = { "SSID4", "Pass4" };
      routers[4] = { "SSID5", "Pass5" };
      Serial.println("[LittleFS] Liste de routers par défaut chargée (5 entrées).");
      bool loadRoutersFromLittleFS() {
      if (!LittleFS.exists("/routers.json")) {
      Serial.println("Fichier routers.json introuvable.");
      return false;
      File file = LittleFS.open("/routers.json", "r");
      if (!file) {
      Serial.println("Échec ouverture fichier routers.json.");
      return false;
      DynamicJsonDocument doc(1024);
      file.close();
      if (err) {
      Serial.println("Erreur parsing JSON (routers).");
      return false;
      JsonArray arr = doc["routers"];
      routerCount = 0;
      Serial.println("[LittleFS] Liste des routers chargés :");
      for (JsonObject o : arr) {
      if (routerCount >= MAX_ROUTERS) break;
      strncpy(routers[routerCount].ssid, o["ssid"], sizeof(routers[routerCount].ssid) - 1);
      strncpy(routers[routerCount].password, o["pwd"], sizeof(routers[routerCount].password) - 1);
      Serial.print(" - SSID: ");
      Serial.print(routers[routerCount].ssid);
      Serial.print(", Password: ");
      Serial.println(routers[routerCount].password);
      routerCount++;
      return true;
      Serial.begin(115200);
      Serial.println("Démarrage du M5Cardputer...");
      auto cfg = M5.config();
      M5Cardputer.begin(cfg, true);
      M5.Display.setRotation(1);
      M5Cardputer.Display.setTextSize(1);
      M5.Display.clear();
      canvas.setTextFont(&fonts::FreeMonoOblique9pt7b);
      canvas.setTextSize(1);
      canvas.pushSprite(3, 120);
      if (!LittleFS.begin(true)) {
      Serial.println("Erreur LittleFS");
      } else {
      Serial.println("LittleFS initialisé.");
      delay(999);
      loadSettingsFromLittleFS();
      Serial.println("Chargement des paramÚtres depuis LittleFS terminé.");
      if (!loadRoutersFromLittleFS()) {
      loadDefaultRouters();
      Serial.println("Chargement des routers terminé.");
      EnTete();
      Serial.println("OLED initialisé.");
      Serial.println("Speaker initialisé.");
      if (!SD.begin()) {
      Serial.println("SD init failed");
      } else {
      Serial.println("SD ready");
      WiFi.mode(WIFI_STA);
      connectToStrongestWiFi();
      timeClient.begin();
      setTime(timeClient.getEpochTime());
      EnTete();
      Corps();
      Pied();
      PiedII();
      resourceMutex = xSemaphoreCreateMutex();
      xTaskCreatePinnedToCore(audioTask, "audioTask", 4096, NULL, 2, &audioTaskHandle, 1);
      checkScreenTimeout();
      handleButtonA();
      bool shouldSync = (mm == 0) && (hh == 9 || hh == 12 || hh == 15 || hh == 18);
      if (shouldSync && lastSyncMinute != (hh * 60 + mm)) {
      lastSyncMinute = hh * 60 + mm;
      if (timeClient.forceUpdate()) {
      unsigned long epoch = timeClient.getEpochTime();
      time_t t = (time_t)epoch;
      struct tm tm;
      gmtime_r(&t, &tm);
      M5.Rtc.setDateTime(&tm);
      if (!triggeredToday && hh == TRIGGER_HOUR && mm == TRIGGER_MINUTE) {
      if (!audioPlaying && SD.exists(WAV_FILENAME)) {
      triggeredToday = true;
      if (hh == 0 && mm == 0) {
      if (screenOn) {
      updateDisplay();
      turnScreenOn();
      PiedII();
      delay(940);
