馃Have you ever tried Chat.M5Stack.com before asking??馃槑
    M5burner software crash problem
    1 Posts 1 Posters 239 Views
    • V Offline
      V22NR
      After downloading and extracting the M5Burner software, my computer is unable to run the M5Burner.exe program. When I double-click M5Burner.exe, Windows directly displays a system pop-up message saying "m5burner has stopped working."
      The following solutions have been attempted but confirmed to be ineffective:
      路 Extract the ZIP archive first, then run M5Burner.exe
      路 Run M5Burner.exe as administrator
      路 Ensure that M5Burner.exe and all other files from the archive are in the same directory, with the path using only half-width characters and the path length not exceeding the Windows system limit
      路 Disable the system VPN and allow M5Burner.exe through the antivirus firewall
      路 Restart the computer
      The following information is related to the error:
      路 Operating environment: Windows 11 Pro 25H2 26200.8524
      路 Information obtained from the m5burner.exe application crash event in Windows Event Viewer is as follows:
      Exception code: 0x80000003
      Faulting process ID: 0x893C
      With your input, this post could be even better 馃挆
