    IR Unit with Core S3
    UiFlow 2.0
    • R
      RPI25
      I was trying to use the IR Unit with my Core S3 in blocks (UIFlow 2.4.0) and it keeps saying there is an invalid timer time. On Port B, with just the Init block and/or the send block, it works fine. No errors. But when I try to receive data, it just brings back the timer error:
        File "<stdin>", line 37, in <module>
        File "<stdin>", line 29, in setup
        File "unit/ir.py", line 24, in rx_cb
        File "driver/ir/nec.py", line 116, in __init__
        File "driver/ir/nec.py", line 67, in __init__
        File "driver/ir/receiver.py", line 47, in __init__
      ValueError: invalid Timer number
      Here is the auto generated code that produced the errors:
      import os, sys, io
      import M5
      from M5 import *
      import m5ui
      import lvgl as lv
      from unit import IRUnit
      import time
      page0 = None
      label0 = None
      label1 = None
      ir_0 = None
      add = None
      dat = None
      def ir_0_rx_event(_data, _addr, _ctrl):
        global page0, label0, label1, ir_0, add, dat
        dat = _data
        add = _addr
        time.sleep(1)
      def setup():
        M5.begin()
        Widgets.setRotation(1)
        m5ui.init()
        page0 = m5ui.M5Page(bg_c=0xffffff)
        label0 = m5ui.M5Label("label0", x=71, y=65, text_c=0x000000, bg_c=0xffffff, bg_opa=0, font=lv.font_montserrat_14, parent=page0)
        label1 = m5ui.M5Label("label1", x=69, y=104, text_c=0x000000, bg_c=0xffffff, bg_opa=0, font=lv.font_montserrat_14, parent=page0)
        ir_0 = IRUnit((8, 9))
        ir_0.rx_cb(ir_0_rx_event)
        page0.screen_load()
        add = 0
        dat = 0
      def loop():
        M5.update()
      if __name__ == '__main__':
        try:
          setup()
          while True:
            loop()
          try:
            m5ui.deinit()
            print_error_msg(e)
          except ImportError:
      Here is the block code:
      Any help much appreciated!
      • P
        Physalice @RPI25
        @RPI25 I'm having the same issues with same and newer version of UIflow 2.4.2, but with cardputer v1.1,Cardputer ADV, and NANO C6. it seems like devs forget to to put IR libraries or something like that into the firmware and didn't noticed it.
        unfortunately they didn't answered me on discord server, and i have no hope getting answer here as well.....
        sending data? yes, no problem. Built in IR and external, but no recieve Т.Т
          felmue @Physalice
          Hi guys
          I can confirm receiving IR from Unit IR is broken for M5Core2 as well.
