    M5Unit C6L Lora initialisation error
    Units
    628
    • H
      HappyUser
      Hi, I am using the following program to test Lora on this model. However, i receive this error: [SX1262] Initializing... Failed, code: -2. I assume that i am using the correct ports as given in rthe documentation. Any suggestions ? Thanks ```
      #include <RadioLib.h>
      //#include <arduino.h>
      #include <M5Unified.h>
      #include <SPI.h>
      // SX1262: CS, IRQ, NRST, BUSY
      SX1262 radio = new Module(23, 7, RADIOLIB_NC, 19);
      bool receiveFlag = false; // flag to indicate that a packet was received
      // function to be called when a complete packet is received
      void setFlag(void) {
      receiveFlag = true;
      #define LORA_MISO 22 //38 //19
      #define LORA_MOSI 21 //23
      #define LORA_SCLK 20 //18
      // auto cfg = M5.config();
      // M5.begin(cfg);
      Serial.begin(115200);
      delay(1000);
      Serial.println("And we have started");
      if (SPI.begin(LORA_SCLK, LORA_MISO, LORA_MOSI,-1))  // SCK, MISO, MOSI, SS
          Serial.println("Fine");
          M5.Display.print("SPI is fine");
      else
           Serial.println("Not fine");
           M5.Display.print("SPI ERROR");
      auto& ioe = M5.getIOExpander(0);
      ioe.digitalWrite(7, false);
      delay(100);
      ioe.digitalWrite(7, true); // re-enable SX_NRST
      ioe.digitalWrite(6, true); // enable SX_ANT_SW
      ioe.digitalWrite(5, true); // enable SX_LNA_EN
      // initialize SX1262
      Serial.print("\n[SX1262] Initializing... ");
      // frequency MHz, bandwidth kHz, spreading factor, coding rate denominator, sync word,
      // output power dBm, preamble length, TCXO reference voltage, useRegulatorLDO
      int beginState = radio.begin(868.0, 125.0, 12, 5, 0x34, 22, 20, 3.0, true);
      if (beginState == RADIOLIB_ERR_NONE) {
      Serial.println("Succeeded!");
      } else {
      Serial.print("Failed, code: ");
      Serial.println(beginState);
      while (true) { delay(100); }
      // set the function to be called when a new packet is received
      radio.setPacketReceivedAction(setFlag);
      // start listening for LoRa packets
      Serial.print("[SX1262] Starting to listen... ");
      int receiveState = radio.startReceive();
      if (receiveState == RADIOLIB_ERR_NONE) {
      } else {
      Serial.println(receiveState);
      if (receiveFlag) { // check if a new packet is received
      receiveFlag = false; // reset the flag
      String str;  // read the received data as an Arduino String
      int readState = radio.readData(str);
      if (readState == RADIOLIB_ERR_NONE) {  // packet was received successfully
        Serial.println("\n[SX1262] Received packet!");
        Serial.print("[SX1262] Data: ");
        Serial.println(str);
        Serial.print("[SX1262] RSSI: ");
        Serial.print(radio.getRSSI());  // Received Signal Strength Indicator
        Serial.println(" dBm");
        Serial.print("[SX1262]  SNR: ");
        Serial.print(radio.getSNR());  // Signal-to-Noise Ratio
        Serial.println(" dB");
        Serial.print("[SX1262] Frequency error: ");
        Serial.print(radio.getFrequencyError());
        Serial.println(" Hz");
      } else if (readState == RADIOLIB_ERR_CRC_MISMATCH) {  // packet was received but malformed
        Serial.println("CRC error!");
      } else {  // some other error occurred
        Serial.println(readState);
      • H
        HappyUser
        I receive this debug error message : GPIO pre-transfer timeout, is it connected? which is located in in the function
        int16_t Module::SPItransferStream(const uint8_t* cmd, uint8_t cmdLen, bool write, const uint8_t* dataOut, uint8_t* dataIn, size_t numBytes, bool waitForGpio)
        in the file Module.cpp
        I am using the example in this M5Stack link : https://docs.m5stack.com/en/arduino/unit_c6l/lora
        Help is appreciated.
        Regards
          felmue @HappyUser
          Hello @HappyUser
          hmm, both examples (w/o any modifications) work for me ok - no error.
          Question: why are you using SPI.begin() in your code? I don't see that in the linked example.
          • H
            HappyUser @felmue
            @felmue Thank you. I tried this extra spi call because I assumed that something is wrong with SPI. Leaving out this call does not solve the problem either. Bot M5Unified and and radiolib are updated. M5Stack board manager is also updated. This is very weird. Not sure how to process further.
            • H
              HappyUser @HappyUser
              @HappyUser
              These are the libs that I am using. Could it be that somehow there is a difference with your config?
              Multiple libraries were found for "SPI.h"
              Used: /Users/..../Library/Arduino15/packages/m5stack/hardware/esp32/3.2.5/libraries/SPI
              Not used: /Users/....../Library/Arduino15/packages/m5stack/hardware/esp32/3.2.5/libraries/_DontUse_SPI
              Using library RadioLib at version 7.3.0 in folder: /Users/....../Documents/Arduino/libraries/RadioLib
              Using library SPI at version 3.2.1 in folder: /Users....../Library/Arduino15/packages/m5stack/hardware/esp32/3.2.5/libraries/SPI
              Using library M5Unified at version 0.2.13 in folder: /Users/....../Documents/Arduino/libraries/M5Unified
              Using library M5GFX at version 0.2.15 in folder: /Users.../Documents/Arduino/libraries/M5GFX
              /Users/....../Library/Arduino15/packages/m5stack/tools/esp-rv32/2411/bin/riscv32-esp-elf-size -A /Users/..../Library/Caches/arduino/sketches/E220783385D73AB555D51793968410FB/LoRa_Test.ino.elf
              Sketch uses 434305 bytes (33%) of program storage space. Maximum is 1310720 bytes.
              Global variables use 17508 bytes (5%) of dynamic memory, leaving 310172 bytes for local variables. Maximum is 327680 bytes.
              esptool.py v4.8.1
              Serial port /dev/cu.usbmodem1101:
              Connecting...
              Connected to ESP32-C6 on /dev/cu.usbmodem1101:
              Chip type: ESP32-C6 (QFN40) (revision v0.2)
              Features: Wi-Fi 6, BT 5 (LE), IEEE802.15.4, Single Core + LP Core, 160MHz
              Crystal frequency: 40MHz
              USB mode: USB-Serial/JTAG
              MAC: 58:8c:81:ff:fe:50:00:08
              BASE MAC: 58:8c:81:50:00:08
              MAC_EXT: ff:fe
              • H
                @HappyUser Well, solved it. Updated M5GFX to 0.2.19 did the trick. What makes me wonder is how tis update is related to a communication issue with the LoRa chap.
                  felmue @HappyUser
                  Hello @HappyUser
                  glad to hear you figured it out.
                  Well, part of M5GFX is used to try to figure out which board is in use. See code starting from here. Maybe this detection went wrong somehow?
                  • H
                    HappyUser @felmue
                    @felmue said in M5Unit C6L Lora initialisation error:
                    here
                    thank you for figuring that out. Honestly, i would have expected that that would be dealt with in M5Unified. Anyway, module works great. Cam right on time on the market because we really need to upgrade our iot devices in the field.
