    StamPLC Run Issue
    4 Posts 3 Posters 922 Views 1 Watching
    • L Offline
      lombric
      I wrote a small program containing only the initialization of a StamPLC module with its “StamPLC AC” power supply.
      When I run “RUN,” the program list is sent to the module, and execution proceeds normally.
      However, when I try to download the program, I get the following message:
      MPY: soft reboot
         _  __ _
      _ ()/ | | _____ __
      | |/ _ \ \ /\ / /
      | || | | | | () \ V V /
      _
      ,||| ||___/ _/_/ V2.4.2
      File "boot.py", line 44, in <module>
      File "startup/init.py", line 1, in startup
      OSError: (-4354, 'ESP_ERR_NVS_NOT_FOUND')
      MicroPython v1.25.0-dirty on 2026-02-08; M5STACK StamPLC with ESP32-S3-FN8
      And the program does not run.
      Could someone help me?
      Thank you in advance for your response.
        Swift_Solutions @lombric
        @lombric I have also discovered this issue today, added the StamPLC AC module into my UiFloww V2.4.3 environment and it crashes the controller. I had to force reboot it and reflash it with M5 Burner to recover it. VERY frustrating as this is a hardware software combination all built by M5 Stack. I have no idea how to resolve this as your post is from Feb 2026 and there are zero responses...
          Swift_Solutions @Swift_Solutions
          For anyone else who has a StamPLC and a StamPLC AC Relay and is having issues using the UIFLOW2 AC Relay Blockly module and getting errors. The below screenshot shows how to use the I2C module to get it working. I used the https://www.diodes.com/datasheet/download/PI4IOE5V6408.pdf datasheet to work out which registers need to be set up to get this working. Keep in mind the LED's work on an opposite logic level to the relay.
          After Some Tinkering I have a working example for anyone else who needs it. UIFlow 2 Stamp PLC AC Relay Working Example Screenshot.jpg
          I did try to share this on the project zone but like most things on here it throws errors instead of just working...
            felmue @Swift_Solutions
            Hi guys
            it looks like another unfortunate regression. If I burn UIFlow2 firmware 2.4.2 onto my M5StamPLC I can control the relay and LED just fine.
            Unfortunately the UIFlow2 firmware source code in github repository uiflow-micropython (at the time of writing this) is still on version 2.4.2. So it's impossible to tell what has changed between 2.4.2 and 2.4.3 causing this issue.
