    Bruce for Cardputer & ADV & RNF24 MOD
    1 Posts 1 Posters 998 Views
      aliense44
      Hi, i made mod to Bruce SV.
      To the basic BRUCE 1.13 in the NRF24 menu I added the NRF SCAN function, which scans the entire range of channels looking for active ones in the area. Before scanning, you can use the ">" button to select the % scanning tolerance. The lower it is, the more channels it will find, but their quality will be poorer, the default is 5%.
      After clicking OK (enter), it will start scanning, after scanning it will display the result - channels, after clicking ">" the program will save the file to memory, which can be used later.
      Now, when you save the file with scanned channels, the NRF Jammer option scans only the found channels in the selected range.
      For example, by default, Bluetooth channels are 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17,18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49,50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65,66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80.
      If any of these channels are in the saved scanner log, the program will spam only these channels and not all of them. This works for any of the possible NRF Jammer options.
      Dadtkowo NRF Jammer now displays data about spammed channels.
      Additionally, CH Jammer has a manual channel setting function. Previously, you had to click the arrows to select a specific channel, now after clicking "c", you can enter the channel manually.
      The Ch Hopper TURBO option has also been added, which allows you to jump through channels much faster than the default CH Hopper option. It can also be set from the keyboard - the "e" button edits the currently selected hopper parameter. The arrow functions still work, but they need to be called like this: Enter and then the arrows, enter and arrows again allow you to select a parameter.
      I will be grateful for testing and any comments. The software is available from M5BURNER
      https://m5burner-cdn.m5stack.com/firmware/c95cf01e19e2248a929d9acb62fb3f87.bin
