    My Tab5 Extended GPIO and Power management library.
    Micropython
    • easytargetE
      easytarget
      Hi all;
      This is something I've been working on; a easy way of taking control of the Tab5's power management circuitry from vanilla MicroPython; without needing a special board build.
      https://codeberg.org/easytarget/tab5-egpio-micropython
      The README there has the full install and usage notes; plus a list of the (30!) methods it provides. This is deigned to be very simple in use; it is self-contained and lets you:
      • Control power on/off for the WiFi chip, Speaker Amplifier, USB-A port and Expansion port 5V power.
      • Switch WiFi between internal and external antennas
      • Enable and disable battery charging, set the quick charge status, read the charge indicator pin.
      • Read the battery voltage and current in/out.
      • Detect if headphones are plugged in.
      • Set LCD backlight brightness
      • Trigger a poweroff event.
      • Send reset signals to the LCD, TouchPanel and Camera modules.
      Use it to create a power control object and set the device up as you need:
      from tab5_egpio import TAB5_EGPIO
      tab5pwr = TAB5_EGPIO()
      tab5pwr.wlan_pwr_on()
      tab5pwr.charge_enable()
      # later (let the charge controller settle first)
      voltage, current = tab5pwr.battery_status()
      print('Battery: {:.2f}V @ {:.3f}A'.format(voltage, current))
      There are some demo's in the repo that show how to use this in more detail. And I have a page where I am documenting general hardware related Tab5 micropython information at: https://codeberg.org/easytarget/m5-tab5-micropython
      [note: I'm cross-posting this here from the micropython official discussions, since it is specific to the Tab5]
        felmue @easytarget
        Hello @easytarget
        for me your current implementation to turn off M5Tab5 actually only does a reset.
        The power off pulse needs to pulse to turn off M5Tab5. See here.
        I modified poweroff_now function in your library like below:
        def poweroff_now(self):
                """Instant full power off. Be sure you want to use this!"""
        #        self._e2.set_output(_PWROFF_PULSE_PIN, HIGH)
                for x in range(10):
                    self._e2.set_output(_PWROFF_PULSE_PIN, LOW)
                    sleep(0.05)
                    sleep(0.05)
        and now my M5Tab5 turns off.
        easytargetE 1 Reply Last reply Reply Quote 0
        • easytargetE
          easytarget @felmue
          Thank you! you are quite right! I hadn't really looked at what was happening properly :-(
          The pin needs to be toggled high then low with a ~50ms delay for a full power off, just toggling it high does a full reset (after 1 second). I really wish there was a state diagram (or similar) available for the code in the PMS150G power control MCU.
          I've extended my code to do the required pulse similar to your modification, and added a reset_device() method too. Plus relevant notes in the README etc, and done a new release.
          [testing shows that the poweroff happens immediately after the first pulse, I'm not sure why they attempt to pulse several times but I guess they are just making sure.. ;-)]
