    GPIO rising/falling events
    3 Posts 3 Posters 2.0k Views
      adamm5
      I'm seeking to remotely monitor a solar pump using a Lora unit and AtomS3 Lite, and need to count pulses from a water meter's hall sensor.
      I see UIFlow1 provides blocks for capturing events on rising (or falling) GPIO inputs, which is what I need, however UIFlow1 won't work with this hardware. I can't find an equivalent on UIFlow2. Or is the PIN BTN 'is pressed' event effectively the same thing? Or do I need to do this in python?
      Adding to my confusion, I get the following from the M5 AI assistant:
      3. UIFlow2 Block Configuration
      Initialize Pin: Use the "Pin" block (under "Hardware") to set the pin number, mode (IN), and pull resistor.
      Set Interrupt: Use the "Pin Interrupt" block to select the trigger edge and assign a handler function (defined via the "Function" block).
      Thats exactly what I want...but there is not such "Pin Interrupt" block that I can find.
        SpyrosEfth
        I have exactly the same problem. I would like to create an interupt to detect GPIO pulses for my Temperature Controller.
          felmue @SpyrosEfth
          Hi guys
          while there doesn't seem to be a Pin Interrupt block you can just put some code into an Execute mpy code block.
          I created an example showing interrupts use on Pins. You can find it in the UIFlow Project Zone called: M5AtomS3_GPIO_Interrupt_UIFlow2.4.0
