    M5burner issue Arch Linux
    3 Posts 2 Posters 1.8k Views 1 Watching
      kumohoshi42
      I'm experiencing multiple issues uploading firmware to the cardputer.
      I'm unable to connect to the cardputer unless I do: "sudo chown 'user' ttyACM0"
      After do this I can verify a connection in m5burner but I can't burn anything if I do it says the following:
      "JavaScript error occurred in the main process"
      "uncaught Exception:
      Error: spawn /mnt/'drive'/'file'/0M5Burner-v3-beta-linux-x64/packages/tool/esptool EACCES
      at Process.ChildProcess._handle.onexit (node:internal/child_process:282:19
      at onErrorNT (node:internal/child_process:477:16)
      at processTicksAndRejections (node:internal/process/task_queues:83:21
      I've also tried running as admin.
      "sudo ./m5burner"
      which returns:
      [1230/051906.244212:FATAL:electron_main_delegate.cc(290)] Running as root without --no-sandbox is not supported. See https://crbug.com/638180.
      fish: Job 1, 'sudo ./m5burner' terminated by signal SIGTRAP (Trace or breakpoint trap)
      so then I tried adding no sandbox "sudo --no--sandbox ./m5burner"
      which returns
      sudo: unrecognized option '--no--sandbox'
      I welcome any suggestions that might fix this sour pickle.
        kumohoshi42 @kumohoshi42
        @kumohoshi42 I solved this if anyone from Arch or any arch based distro.
        The Java exception was created because my user doesn't have permission to make a folder in /mnt.
        To fix this I used bash to create a folder called "drive" and then I could make a folder in that called "folder".
        Then for safety I copied the m5burner folder to there and that's where I'm gonna burn from.
        I hope this helps any future Arch users <3 <3
        bschwahnB 1 Reply Last reply Reply Quote 0
        • bschwahnB Online
          bschwahn @kumohoshi42
          @kumohoshi42
          Thanks for sharing how you resolved the problem!
          What doesn't kill me makes me stronger.
