    UiFlow 2.1.3 Web app export to .py for use on CoreS3
    UiFlow 2.0
    5
    6
    2.4k
    • Coopersmith-24601C
      Coopersmith-24601
      I want to be able to load small apps I've created in UiFlow 2.1.3 web app into the UiFlow 2 "APP LIST" running on my CoreS3.
      It looks like I can only do that if they are .py files.
      How can I export the UiFlow 2.1.3 PYTHON section as a .py file? Or load them directly into the UiFlow 2 "APP LIST" running on my CoreS3.
      Clearly the UiFlow 2.1.3 programmers must have included such an obvious function; right?
      • lbuqueL
        lbuque @Coopersmith-24601
        This will save a copy of the py file to the apps directory. You can then see it in APP.LIST.
        Coopersmith-24601C 1 Reply Last reply Reply Quote 0
          Coopersmith-24601 @lbuque
          @lbuque This is not the behavior I'm seeing at all.
          For me, pressing that button will download the file to the CoreS3 and replaces the UiFlow2 app on the CoreS3 as well.
          The only way I can ever get back to UiFlow2 on the CoreS3 is to reload it completely from the M5Burner.
          • R
            roddpap
            The only way I found was to copy the Python code from UIFLOW2, paste it in Thonny and save it as a .py file. Then upload it using the WebTerminal in UI FLoW 2 interface
              sssouthpaw
              Hello.
              Has this been fixed? It still overwrites the whole UiFlow2 app and I have to use the M5Burner to bring it back. Making the .py file manually and uploading it to the app folder is a pain.
              I am using a M5Go / Core1.
              • R
                RPI25 @sssouthpaw
                @sssouthpaw Yes I think the only way to do it is to copy the python file and then paste it into Thonny or VSCode before uploading through the file manager in the UIFlow terminal to get the python file on the device.
