    AtomS3R with Atomic Echo Base Chatbot
    Atom
    • A
      alperkal
      Hi, I have the
      and have this set up as described on the website. All good and works as expected.
      But I want to modify the code and add more features: eg: only activate listening when we press the button.
      Now the documentation points me to a branch in this repository.
      https://github.com/m5stack/openai-realtime-embedded-sdk
      But when I build from the source and install on the device without making any change, it stops working. It looks like the version on M5Burner has more than the given driver repository. So can we get access to full source code and the missing link between the embedded sdk and the image that is installed from the m5burner?
      • A
        arn0nym @alperkal
        @alperkal said in AtomS3R with Atomic Echo Base Chatbot:
        Hi, I have the
        when I Install the OpenAI VOice Assistant firmware for S3R Echo Base it does nto do anything for me. just displays the OpenAI logo and that's it. the comments on the firmware also say that it mostly does not work :/ I was searching left and right to find a proper sketch or any code that I can configure myself, too!
