    Firev2.7 Test결과 PSRAM이 인식이안됩니다.
    Scheduled Pinned Locked Moved M5Stack Fire
    1 Posts 1 Posters 423 Views 1 Watching
    • nongjung-dnsN Offline
      nongjung-dns
      Re: [Fire with UIFlow2](/topic/6685/fire```
      code_text
      # /flash/mem_fire_check.py
      # check_psram_status.py - M5Stack Fire PSRAM Detection Script
      import gc
      import os
      import sys
      import machine
      def check_psram_status():
          print("M5Stack Fire PSRAM Detection Status")
          print("=" * 50)
          # 1. System information
          print("1. System Information:")
          print(f" - MicroPython version : {sys.implementation.version}")
          print(f" - Platform           : {sys.platform}")
          print(f" - Machine            : {os.uname().machine}")
          # 2. Official esp32 PSRAM API check
          print("\n2. Official PSRAM API Check:")
          try:
              import esp32
              if hasattr(esp32, 'PSRAM'):
                  size = esp32.PSRAM.size()
                  print(f"   esp32.PSRAM available: {size:,} bytes "
                        f"({size / 1024 / 1024:.1f} MB)")
              else:
                  print("   esp32.PSRAM attribute NOT found")
          except Exception as e:
              print(f"   Failed to access esp32.PSRAM → {e}")
          # 3. Current heap status
          print("\n3. Heap Memory Status:")
          gc.collect()
          total_heap = gc.mem_alloc() + gc.mem_free()
          print(f" - Total heap   : {total_heap:,} bytes ({total_heap / 1024 / 1024:.2f} MB)")
          print(f" - Allocated    : {gc.mem_alloc():,} bytes")
          print(f" - Free         : {gc.mem_free():,} bytes")
          # 4. PSRAM allocation stress test
          print("\n4. PSRAM Allocation Test (512KB chunks):")
          test_psram_allocation()
          print("=" * 50)
      def test_psram_allocation():
          gc.collect()
          start_free = gc.mem_free()
          buffers = []
          chunk_size = 512 * 1024  # 512KB
          try:
              for i in range(1, 17):  # Try up to ~8MB
                  buf = bytearray(chunk_size)
                  buffers.append(buf)
                  allocated = len(buffers) * chunk_size
                  current_free = gc.mem_free()
                  print(f"   {allocated / 1024 / 1024:.1f} MB allocated → "
                        f"{current_free / 1024 / 1024:.2f} MB free")
                  # If free memory drops too fast → we're NOT using PSRAM
                  if start_free - current_free > (start_free * 0.8):
                      print("   Sudden heap drop detected → Running WITHOUT PSRAM")
                      break
          except MemoryError:
              print(f"   MemoryError at {allocated / 1024 / 1024:.1f} MB → "
                    "PSRAM is NOT enabled in firmware")
              print(f"   Unexpected error: {e}")
          finally:
              del buffers[:]
              gc.collect()
              print(f"   Cleanup complete → Free memory: "
                    f"{gc.mem_free() / 1024 / 1024:.2f} MB")
      def check_firmware_psram_support():
          print("\n5. Firmware PSRAM Support Summary:")
          print("   Testing different detection methods...")
          results = []
          # Method 1: esp32.PSRAM
          try:
              import esp32
              if hasattr(esp32, 'PSRAM') and esp32.PSRAM.size() > 0:
                  results.append("esp32.PSRAM API → Supported "
                                f"({esp32.PSRAM.size() / 1024 / 1024:.1f} MB)")
              else:
                  results.append("esp32.PSRAM API → Not available")
          except:
              results.append("esp32.PSRAM API → Failed to import")
          # Method 2: Large allocation test
          gc.collect()
          try:
              _ = bytearray(6 * 1024 * 1024)  # 6MB
              results.append("Large allocation (6MB+) → SUCCESS (PSRAM likely enabled)")
              del _
          except MemoryError:
              results.append("Large allocation (6MB+) → FAILED (NO PSRAM)")
          gc.collect()
          # Final verdict
          for r in results:
              print(f"   • {r}")
          print("\n   Verdict:")
          if any("SUCCESS" in r or "Supported" in r for r in results):
              print("   PSRAM is ENABLED and working!")
          else:
              print("   PSRAM is DISABLED → Flash a PSRAM-enabled firmware!")
      # Main execution
      if __name__ == "__main__":
      ------------- Result    =============
      MicroPython v1.25.0-dirty on 2025-10-24; M5STACK Fire with ESP32(SPIRAM)
      >>> import check_psram_status as pp
      >>> pp.check_psram_status
      <function check_psram_status at 0x3f8034c0>
      >>> pp.check_psram_status()
       - MicroPython version : (1, 25, 0, '')
       - Platform           : esp32
       - Machine            : M5STACK Fire with ESP32(SPIRAM)
       - Total heap   : 4,184,768 bytes (3.99 MB)
       - Allocated    : 7,856 bytes
       - Free         : 4,176,864 bytes
         0.5 MB allocated → 3.42 MB free
         1.0 MB allocated → 2.91 MB free
         1.5 MB allocated → 2.40 MB free
         2.0 MB allocated → 1.90 MB free
         2.5 MB allocated → 1.46 MB free
         3.0 MB allocated → 0.96 MB free
         3.5 MB allocated → 0.46 MB free
         Cleanup complete → Free memory: 3.44 MB
