    Issue with Port C (UART) of M5Stack Fire (Finger unit OK but GPS No Good)
    M5Stack Fire
    7
    13.2k
    • liemphL
      liemph
      I am aware that there is an issue related to the UART port (Port C) of M5Stack Fire. However, using the UIFlow (1.4.5) I managed to connect and program the Finger unit normally. However, with the GPS unit, I failed to make it work. I do not understand why for the core works with the Finger unit but not with the GPS (same Port C).
      ajb2k3A nongjung-dnsN 2 Replies Last reply Reply Quote 1
        ajb2k3 @liemph
        @liemph do you get an error message or just no response?
        • liemphL
          liemph @ajb2k3
          @ajb2k3 said in Issue with Port C (UART) of M5Stack Fire (Finger unit OK but GPS No Good):
          Your question alerted me. I used the GPS example provided by M5 for UiFlow. The LCD showed that the Time is 00:00:00, no data in Lattitude and Longitude, the Quality showed NO Signal. I tested it at home (inside my house). So is it possible that I have to look for a better place to get a stronger signal? However other devices using GPS work well inside my house.
            ajb2k3 @liemph
            @liemph Try connecting the m5stack to a pc and opening a terminal connecting to the M5Stack.
            the terminal may show more information.
            • liemphL
              liemph @ajb2k3
              I took the log file by using teraterm serial monitor program. I did not see any valuable information for debugging. This is the results:
              ets Jun 8 2016 00:22:57
              rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
              configsip: 0, SPIWP:0xee
              mode:DIO, clock div:1
              load:0x3fff0018,len:4
              load:0x3fff001c,len:6272
              ho 0 tail 12 room 4
              load:0x40078000,len:9848
              ho 0 tail 12 room 4
              load:0x40080400,len:6504
              entry 0x4008072c
              I (32) boot: ESP-IDF v3.3-beta1-696-gc4c54ce07 2nd stage bootloader
              I (32) boot: compile time 19:36:27
              I (32) boot: Enabling RNG early entropy source...
              I (38) boot: SPI Speed : 80MHz
              I (42) boot: SPI Mode : DIO
              I (46) boot: SPI Flash Size : 16MB
              I (50) boot: Partition Table:
              I (54) boot: ## Label Usage Type ST Offset Length
              I (61) boot: 0 nvs WiFi data 01 02 00009000 00006000
              I (69) boot: 1 phy_init RF data 01 01 0000f000 00001000
              I (76) boot: 2 factory factory app 00 00 00010000 001f0000
              I (83) boot: 3 internalfs Unknown data 01 81 00200000 001ff000
              I (91) boot: End of partition table
              I (95) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0xe970c (956172) map
              I (379) esp_image: segment 1: paddr=0x000f9734 vaddr=0x3ffbdb60 size=0x034dc ( 13532) load
              I (383) esp_image: segment 2: paddr=0x000fcc18 vaddr=0x40080000 size=0x00400 ( 1024) load
              I (386) esp_image: segment 3: paddr=0x000fd020 vaddr=0x40080400 size=0x02ff0 ( 12272) load
              I (398) esp_image: segment 4: paddr=0x00100018 vaddr=0x400d0018 size=0xdbea8 (900776) map
              I (662) esp_image: segment 5: paddr=0x001dbec8 vaddr=0x400833f0 size=0x12bf8 ( 76792) load
              I (688) esp_image: segment 6: paddr=0x001eeac8 vaddr=0x400c0000 size=0x00064 ( 100) load
              I (688) esp_image: segment 7: paddr=0x001eeb34 vaddr=0x50000000 size=0x00808 ( 2056) load
              I (708) boot: Loaded app from partition at offset 0x10000
              I (709) boot: Disabling RNG early entropy source...
              I (709) cpu_start: Pro cpu up.
              I (713) cpu_start: Application information:
              I (717) cpu_start: Compile time: Mar 13 2020 19:36:49
              I (724) cpu_start: ELF file SHA256: 0000000000000000...
              I (730) cpu_start: ESP-IDF: v3.3-beta1-696-gc4c54ce07
              I (736) cpu_start: Starting app cpu, entry point is 0x400836e4
              I (0) cpu_start: App cpu up.
              I (746) heap_init: Initializing. RAM available for dynamic allocation:
              I (753) heap_init: At 3FFAE6E0 len 0000F480 (61 KiB): DRAM
              I (759) heap_init: At 3FFCB2C8 len 00014D38 (83 KiB): DRAM
              I (766) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
              I (772) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
              I (778) heap_init: At 40095FE8 len 0000A018 (40 KiB): IRAM
              I (785) cpu_start: Pro cpu start user code
              I (131) cpu_start: Starting scheduler on PRO CPU.
              I (0) cpu_start: Starting scheduler on APP CPU.
              Internal FS (FatFS): Mounted on partition 'internalfs' [size: 2093056; Flash address: 0x200000]
              Filesystem size: 2031616 B
              Used: 1605632 B
              Free: 425984 B
              I (359) [TFTSPI]: attached display device, speed=8000000
              I (359) [TFTSPI]: bus uses native pins: false
              W (534) sdspi_host: spi bus changed (1 -> 2)
              E (577) sdmmc_sd: sdmmc_init_spi_crc: sdmmc_send_cmd_crc_on_off returned 0x106
              [ M5 ] init sd card Fail
              [ M5 ] node id:<deleted>, api key:<deleted>
              I (2018) uart: ALREADY NULL
              Please note that I deleted the node id and api key.
              • M5StickFreaklerM
                M5StickFreakler @liemph
                @liemph
                Same problem here :-(
                https://forum.m5stack.com/topic/1930/gps-unit-at6558
                • nongjung-dnsN
                  nongjung-dns @liemph
                  @liemph
                  Fire Has PSRAM .. use Port C PIN ..
                  so it can't use Port C .
                  Fire 는PSRAM 이 있어요 그것이 C 포트에 GPIO를 사용합니다.
                  그래서 C 포트를 사용할수가 없답니다.
                  이 내용은 챗봇이 무척 많이 알려준 내용입니다..
