    TAB5 python Crash
    PRODUCTS
      scroggyg
      I was trying to write an output on EXTIo2 and I got a python crash and a dump.
      I then tried to update the TAB5 to V2.3.6-hotfix2.
      The device programmed and the default UIFlow screen is showing, but now I cannot program the device.
      I reverted to 2.3.5 and I can program the TAB5
        felmue @scroggyg
        Hello @scroggyg
        here are the result of my tests with various firmware versions:
        v2.3.5 : running program -> crash
        v2.3.6 : running program -> crash
        v2.3.6 hotfix : running program -> ok
        v2.3.6 hotfix2 : running program -> ok
        Note:
        • I had no issue burning an running any of the above firmware versions.
        • I run all my tests with no battery attached.
        You can find the program I used in the UIFlow Project Zone: M5Tab5_ExtIO2_Test_UIFlow2.3.6
