    Replacement battery?
    Core 2
    2.5k
    • G
      GeorgeR
      My Core2 battery wasn't charging, so I opened it up and saw the battery or all puffy, usually indicating it's broken.
      I've looked around but can't find a battery that matches, does anyone know of one?
      390mAH
      picoblade connector
      20mm x 29mm
        ajb2k3 @GeorgeR
        @GeorgeR Have you tried emailing M5Stack?
        • G
          GeorgeR @ajb2k3
          @ajb2k3 I haven't, but just did!
          • G
            GeorgeR @GeorgeR
            Right, so I never received a response. I know I can get a new base, but I really only want the battery as a base will add extra bulk to the unit.
              SiberianHamster @GeorgeR
              @GeorgeR
              Have a search for 'quadcopter battery' on Amazon (or your marketplace of choice) and you should find one of the right size and correct connector. I've bought a couple of batteries and charged them with the 'Timer Power Unit' for various projects.
              WARNING!! BEWARE! I've found about 50% of the batteries I've bought had the wires the opposite way round to that required by the M5Stack controllers. They will instantly kill your controller! Triple check the polarity before ever plugging them into your controller.
