    ATOMIC PoE Base W5500 POE+DHCP doesn't work
    Scheduled Pinned Locked Moved Bases
    4 Posts 2 Posters 3.2k Views
    • X Offline
      xgonc
      I'm using the ATOMIC PoE Base W5500 (SKU: A091).
      In Arduino environment, I'm using DHCP. Powering the AtomS3 lite with USB all works fine. However, when I use POE, DHCP doesn't work any more.
      I'm using the following to setup the Ethernet interface:
          #define CS 6
          Ethernet.init(CS);
          while(!Ethernet.begin(mac)) {
             Serial.println("Ethernet.begin failed");
          if (Ethernet.hardwareStatus() == EthernetNoHardware)
              Serial.println(
                  "Ethernet shield was not found.  Sorry, can't run without "
                  "hardware. :(");
              while (true)
                  delay(1); // do nothing, no point running without Ethernet hardware
          if (Ethernet.linkStatus() == LinkOFF)
              Serial.println("Ethernet cable is not connected.");
      With POE enabled, the code get stucked at the fisrt loop.
      Is there anything missing?
        felmue @xgonc
        Hello @xgonc
        maybe try with a short delay() before the first loop?
        BTW: the included PoE example works for me.
        • X Offline
          xgonc @felmue
          @felmue Thanks for your reply.
          Meanwhile I confirmed being powered by POE has no effect. The problem is the interface never gets an address from the DHCP server.
          With a fixed address, everything is fine.
          Did you try any other Ethernet lib?
          Thanks.
            felmue @xgonc
            Hello @xgonc
            no, I did not try any other Ethernet library.
