    LittleFS problem with M5core2 and PIO
    Core 2
    4.1k
    • L
      Leo05
      Here is my platformio config:
      [env:m5stack-core2]
      platform = espressif32
      board = m5stack-core2
      framework = arduino
      board_build.filesystem = littlefs
      monitor_speed = 115200
      lib_deps =
      ottowinter/ESPAsyncWebServer-esphome@^2.1.0
      m5stack/M5Core2@^0.1.0
      lorol/LittleFS_esp32@^1.0.6
      With that config, I cannot upload files in memory. it always save the file as spiffs.
      Auto-detected: /dev/ttyUSB0
      Uploading .pio/build/m5stack-core2/spiffs.bin
      esptool.py v3.1
      Serial port /dev/ttyUSB0
      Connecting....
      Chip is ESP32-D0WDQ6-V3 (revision 3)
      Crystal is 40MHz
      MAC: 84:cc:a8:5f:ea:08
      Uploading stub...
      Running stub...
      Stub running...
      Changing baud rate to 460800
      Changed.
      Configuring flash size...
      Auto-detected Flash size: 16MB
      Flash will be erased from 0x00c90000 to 0x00ffffff...
      Compressed 3604480 bytes to 155100...
      Writing at 0x00c90000... (10 %)
      Writing at 0x00ca61ce... (20 %)
      Writing at 0x00cbe455... (30 %)
      Writing at 0x00cd3e90... (40 %)
      Writing at 0x00ce9a6c... (50 %)
      Writing at 0x00cff565... (60 %)
      Writing at 0x00d13a71... (70 %)
      Writing at 0x00d2bf09... (80 %)
      Writing at 0x00d4a5ce... (90 %)
      Writing at 0x00d7257e... (100 %)
      It upload succesfully but then fail to access the file from the server.
      .pio/libdeps/m5stack-core2/LittleFS_esp32/src/lfs.c:1076:error: Corrupted dir pair at {0x0, 0x1}
      E (6257) esp_littlefs: mount failed, (-84)
      E (6261) esp_littlefs: Failed to initialize LittleFS
      [E][LITTLEFS.cpp:90] begin(): Mounting LITTLEFS failed! Error: -1
      • H
        hacxx Banned
        It looks like PlatformIO is still uploading your filesystem as SPIFFS despite setting board_build.filesystem = littlefs. This happens because the default partition table might not reserve space for LittleFS. Try creating a custom partition table that supports LittleFS and specify it in platformio.ini with board_build.partitions. Also, ensure your LittleFS_esp32 library is compatible with M5Core2. Without proper partitioning, mounting fails with corrupted directory errors like yours. Let me know if you want help generating a suitable partition CSV file!
