    Is the Battery Module for ESP32 Core Development Kit compatible with M5Stack Fire 2.7
    PRODUCTS
    • G
      gbastos
      Hello guys,
      I want to add more battery to my M5Stack Fire 2.7, and I would like to know if this module https://shop.m5stack.com/products/battery-module is compatible with my M5Stack Fire.
      By that, where can I find screws to assemble everything together, so my clients, don't disassembly the parts?
      Thanks in advance.
        sanjaay
        Hi!
        Yes, the M5Stack Battery Module works with the M5Stack Fire 2.7. M5Stack's stackable header-pin design allows you to simply add modules like this one without needing to solder.
        Use M2 screws (22mm or longer) and M2 brass spacers to securely assemble everything. This maintains the modules securely packed, which is ideal for preventing inadvertent disassembly, particularly in client-facing installations.
        If you are in India, check out Robocraze. They are an approved M5Stack distributor, providing accessories and assistance for clean, professional builds.
        Hope this helps!
