    LoRaWAN EU868 RAK3172(H) program issue
    PRODUCTS
    • C
      charlesRD
      I’m encountering an issue while using the LoRaWAN EU868 RAK3172(H). I created a program to read temperature data using a KMeterISO sensor in UIFlow2, which works perfectly with the older and simpler LoRaWAN868 ASR6501. However, when I switched to the RAK module and updated the configuration in the "Unit" section of UIFlow2, I encountered the following error: AttributeError: LoRaWANUnit_RUI3
      This error appears to come from a library that is automatically added when I configure the RAK module's pins.
      While searching for a solution, I visited the product's documentation page:
      • https://docs.m5stack.com/en/unit/Unit LoRaWAN-EU868
        There, it states that UIFlow1 and UIFlow2 support is coming soon — meaning it’s not currently available.
      As a result, I decided to switch to the Arduino IDE. I downloaded the appropriate library and attempted to run an example program, but even the basic example fails to work with this module, i got stuck in the 1st while loop.
      According to the official documentation, the library to use is the one following :
      • https://github.com/m5stack/M5-LoRaWAN-RAK
      The example I tried to compile was:
      Examples > LoRaWAN > OTAA,
      with the correct pin configuration and OTAA identification (DevEUI, AppEUI, AppKey).
      So i try on my own a program but here again, i got stuck in the 1st while loop again. Here's the program that i can compile but not working (I know the OTAA identification is not submit here) :
      #include <Wire.h>
      #include <M5Unified.h>
      #include <M5UnitKmeterISO.h>
      #include "rak3172_lorawan.hpp"
      #include <string.h>
      RAK3172LoRaWAN lorawan;
      M5UnitKmeterISO kmeter;
      // Définir les paramètres OTAA
      #define DEVEUI ""
      #define APPEUI "
      #define APPKEY "*********"
      // Déclaration des broches pour LoRa
      #define TX 15
      #define RX 13
      void joinCallback(bool status)
      if (status) {
      Serial.println("[LoRaWAN] Join réseau réussi !");
      } else {
      Serial.println("[LoRaWAN] Échec de la jonction !");
      void sendCallback()
      Serial.println("[LoRaWAN] Envoi confirmé par le serveur");
      void errorCallback(char* error)
      Serial.print("[LoRaWAN] Erreur : ");
      Serial.println(error);
      Serial.begin(115200);
      // Initialisation du capteur KMeterISO
      Wire.begin(9, 7);  // Utilisation des broches spécifiques pour I2C (SCL, SDA)
      while (!kmeter.begin(&Wire, KMETER_DEFAULT_ADDR)) {
          Serial.println("Capteur KMeterISO non trouvé !");
          delay(1000);  // Attente avant de réessayer
      Serial.println("Capteur KMeterISO initialisé.");
      // Initialisation du module LoRaWAN
      while (!lorawan.init(&Serial2, RX, TX, RAK3172_BPS_115200)) {
          Serial.println("[Init] Failed to initialize module, retrying...");
          delay(1000);
      Serial.println("Module LoRaWAN initialisé.");
      // Configuration LoRaWAN
      lorawan.onJoin(joinCallback);
      lorawan.onSend(sendCallback);
      lorawan.onError(errorCallback);
      // Configurer OTAA
      lorawan.setOTAA(DEVEUI, APPEUI, APPKEY);
      // Tentative de jonction au réseau LoRaWAN
      if (lorawan.join(true, false, 10, 10)) {
          Serial.println("Start Join...");
      } else {
          Serial.println("Join Fail");
      // Configuration du mode LoRaWAN
      lorawan.setMode(CLASS_A);
      lorawan.setLinkCheck(ALLWAYS_LINKCHECK);
      lorawan.setDR(4);  // Data Rate DR4
      Serial.println("Initialisation terminée.");
      M5.update();
      // Lire la température du capteur KMeterISO
      float temp = kmeter.getCelsiusTempValue() / 100.0;
      Serial.printf("Température du capteur: %.2f °C\n", temp);
      // Préparer le message à envoyer
      String message = "Temp: " + String(temp, 2) + " °C";
      // Envoyer le message via LoRaWAN
      if (lorawan.send(message)) {
          Serial.println("Données envoyées avec succès !");
      } else {
          Serial.println("Échec de l'envoi des données.");
      delay(15000);  // Attente de 15 secondes avant de lire et envoyer à nouveau
      C M 2 Replies Last reply Reply Quote 0
      • C
        charlesRD @charlesRD
        @charlesRD said in LoRaWAN EU868 RAK3172(H) program issue:
        As a result, I decided to switch to the Arduino IDE (even if i wanted to stick with UIFlow2). I downloaded the appropriate library and attempted to run an example program, but even the basic example fails to work with this module, i got stuck in the 1st while loop.
          mikeluyten @charlesRD
          @charlesRD I also found this to be a problem with UiFlow2, and found that the unit init.py file is missing the required entry for the LoRaWAN module. I have raised an issue in Github, and submitted a pull request to get it fixed.
