    EZData2 unable to POST to?
    1 Posts 1 Posters 857 Views
      Shortcut3928
      Hi all,
      Here is what I am testing:
      Sending data in a POST call to Ezdata.
      I've set up my data key in EzData and can successfully use the url given on the share button.
      https://ezdata2.m5stack.com/api/v2/..token../data
      However I cannot find the correct url to POST data?
      curl -X POST https://ezdata2.m5stack.com/api/v2/store/[token]/HA_climate
      -H "Content-Type: application/json"
      -d '{"value": "Test from curl"}'
      {"timestamp":"2025-04-24T23:05:34.037+00:00","status":404,"error":"Not Found","path":"/api/v2/store/[token]/HA_climate"}%
      I have also tried "v2/entry/", "v2/input/"
      It would be great if I could send data using the API into Ezdata so I can use blocky to design apps to use that data.
      Any help appreciated. Cheers.
