    atom lite lorawan network connectivity issue
    2 Posts 1 Posters 2.3k Views
      aiconnection
      Hi
      i am trying to connect atom lite and lorawan 915 lorawan module (via UART PORT TO UART POT OF ATOM LITE) to lorawan network and not having much luck. here is the code.
      from machine import UART
      import time
      import ubinascii
      LoRaWAN credentials
      DEV_EUI = "XXXXXXXXXX"
      APP_EUI = "9F8E71DD3AFE41XX"
      APP_KEY = "b4b5c65a175d5f441ee85686b1253XXX"
      UART configuration (G26, G32; change to G19, G22 if needed)
      uart = UART(2, baudrate=115200, tx=26, rx=32, bits=8, parity=None, stop=1, txbuf=256, rxbuf=256)
      State constants
      NOT_JOINED = "NOT_JOINED"
      JOINING = "JOINING"
      JOINED = "JOINED"
      SENDING = "SENDING"
      SENT = "SENT"
      RETRY = "RETRY"
      Simple cooperative scheduler
      class Tasks:
      def init(self):
      self.tasks = []
      def now(self, func):
          self.tasks.append((func, 0, False))
      def after(self, delay_ms, func):
          self.tasks.append((func, time.ticks_add(time.ticks_ms(), delay_ms), False))
      def when_then(self, condition_func, then_func):
          self.tasks.append((then_func, 0, condition_func))
      def only_one_of(self, task1, task2):
          self.tasks.append(task1)
          self.tasks.append(task2)
          self.tasks[-2] = (task1[0], task1[1], lambda: task1[2]() and not task2[2]())
          self.tasks[-1] = (task2[0], task2[1], lambda: task2[2]() and not task1[2]())
      def available(self):
          return len(self.tasks) > 0
      def run(self):
          if not self.tasks:
              return
          current_time = time.ticks_ms()
          for i, (func, trigger_time, condition) in enumerate(self.tasks[:]):
              if condition:
                  if condition():
                      self.tasks.pop(i)
                      func()
                      break
              elif trigger_time == 0 or time.ticks_diff(current_time, trigger_time) >= 0:
                  self.tasks.pop(i)
                  func()
                  break
          time.sleep_ms(10)
      Modem state management
      class Modem:
      def init(self, uart):
      self.uart = uart
      self.state = NOT_JOINED
      self.state_changed = False
      def send_at_command(self, cmd, timeout=1000):
          print(f"Sending: {cmd}")
          self.uart.write(cmd + "\r\n")
          time.sleep_ms(timeout)
          response = ""
          while self.uart.any():
              response += self.uart.read().decode()
          print(f"Response: {response}")
          return response
      def send_join(self):
          self.state = JOINING
          self.state_changed = True
          self.send_at_command("ATZ", 2000)
          self.send_at_command("AT+BAND=5", 1000)  # US915
          self.send_at_command(f"AT+DEVEUI={DEV_EUI}", 1000)
          self.send_at_command(f"AT+APPEUI={APP_EUI}", 1000)
          self.send_at_command(f"AT+APPKEY={APP_KEY}", 1000)
          self.send_at_command("AT+NJM=1", 1000)  # OTAA
          self.send_at_command("AT+CLASS=C", 1000)
          self.send_at_command("AT+MASK=0002", 1000)  # Channels 8-15
          response = self.send_at_command("AT+JOIN=1:0:10:8", 10000)
          if "OK Join Success" in response:
              self.state = JOINED
          else:
          return response
      def send_message(self, data, confirmed=False):
          self.state = SENDING
          hex_data = ubinascii.hexlify(data).decode()
          self.send_at_command(f"AT+PORT=2", 1000)
          cmd = f"AT+SEND={hex_data}" if not confirmed else f"AT+CSEND={hex_data}"
          response = self.send_at_command(cmd, 5000)
          if "OK" in response:
              self.state = SENT
          else:
              self.state = RETRY
          return response
      def has_state_changed(self):
          changed = self.state_changed
          return changed
      def get_state(self):
          return self.state
      Initialize modem and tasks
      modem = Modem(uart)
      tasks = Tasks()
      count = 0
      Modem state check
      def modem_state_changed():
      try:
      return modem.has_state_changed()
      except Exception as e:
      print(f"Modem state error: {e}")
      return False
      Join network
      def start_join():
      print("Joining TTN...")
      try:
      modem.send_join()
      tasks.when_then(modem_state_changed, end_join)
      print(f"Join error: {e}")
      tasks.after(60000, start_join)
      def end_join():
      try:
      state = modem.get_state()
      if state == JOINING:
      elif state == JOINED:
      print("Joined TTN!")
      tasks.after(10000, start_send)
      elif state == NOT_JOINED:
      print("Join failed.")
      else:
      raise NotImplementedError(f"Unknown state: {state}")
      print(f"End join error: {e}")
      Send data
      def start_send():
      global count
      count += 1
      print(f"Sending data: {count}")
      try:
      modem.send_message(bytes(str(count), 'ASCII'), count % 29 == 1)
      tasks.when_then(modem_state_changed, end_send)
      print(f"Send error: {e}")
      tasks.after(300000, start_send)
      def end_send():
      try:
      if state == SENDING:
      tasks.only_one_of(
      (end_send, 0, modem_state_changed),
      (assume_sent, time.ticks_add(time.ticks_ms(), 60000), lambda: True)
      elif state == SENT:
      print("Data sent!")
      elif state == RETRY:
      print("Send failed.")
      print("Not joined.")
      tasks.after(300000, start_join)
      else:
      print(f"End send error: {e}")
      def assume_sent():
      print("Assumed data sent.")
      tasks.after(240000, start_send)
      Start the process
      try:
      tasks.now(start_join)
      while tasks.available():
      tasks.run()
      print(f"Main loop error: {e}")
      time.sleep(10)
      machine.reset()
        aiconnection
        Version: RUI_4.0.6_RAK3172-E
        Current Work Mode: LoRa P2P.
        Sending: AT+BAND=5
        Response: AT_MODE_NO_SUPPORT
        Sending: AT+DEVEUI=AC1F09FFFE16EE10
        Sending: AT+APPEUI=9F8E71DD3AFE41B2
        Sending: AT+APPKEY=b4b5c65a175d5f441ee85686b12534a8
        Sending: AT+NJM=1
        Sending: AT+CLASS=C
        Sending: AT+MASK=0002
        Sending: AT+JOIN=1:0:10:8
        Join failed.
        E (100362) i2c: i2c driver install error
        E (100364) time: The current date/time in Shanghai is: Mon Apr 21 21:19:27 2025
        E (100367) wifi:NAN WiFi stop
        E (100368) transport_base: poll_read select error 113, errno = Software caused connection abort, fd = 54
        E (100376) mqtt_client: Poll read error: 119, aborting connection
        [INFO] Syncing resources...
        [INFO] WiFi connected!
        Joining TTN...
        Sending: ATZ
        Response:
        RAKwireless RAK3172
        Sending: AT+BAND=5
        Sending: AT+NJM=1
        Sending: AT+CLASS=C
        Join failed.
