    Wifi Invalid Mode
    UiFlow 2.0
    • J
      JensH
      Hi All,
      I have an issue where, if I create this as main.py, I will get an error when I try to start my M5 paper. The error is Wifi Invalid Mode.
      My script is below. I have the same configuration in M5 burner and it seems to correctly trying to start main.py as I get the error straight away. If I chose to show the menu at start up then I can see the M5 paper in UIFlow 2 and I can see the device has connected to my account. Any ideas? It's a bit of a pain having choose the app from the applist on the devices screen, but I can run it like that. My app is a bit more complicated than this but this script does the same thing:
      import os, sys, io
      import M5
      from M5 import *
      import network
      label0 = None
      wlan = None
      def setup():
      global label0, wlan
      wlan = network.WLAN(network.STA_IF)
      M5.begin()
      Widgets.fillScreen(0xeeeeee)
      label0 = Widgets.Label("label0", 124, 542, 1.0, 0xffffff, 0x000000, Widgets.FONTS.DejaVu18)
      wlan.connect('network', 'testtesttest')
      label0.setFont(Widgets.FONTS.DejaVu24)
      label0.setText(str(wlan.ifconfig()[0]))
      def loop():
      global label0, wlan
      M5.update()
      if name == 'main':
      try:
      setup()
      while True:
      loop()
      try:
      print_error_msg(e)
      except ImportError:
      Thanks,
        felmue @JensH
        Hello @JensH
        please check my example in UIFlow2 Project Zone: M5Paper_WLAN_Test_UIFlow2.2.5
        • J
          JensH @felmue
          Thanks Felix. I've added the same delay as in your code and that has fixed my issue. I still have an error in the terminal if I have it connected to my PC but at least the app is functioning now and I can restart my M5 Paper straight into the app.
          Thanks very much for your help.
          J
