(M5CoreS3)I2S和ES7210做了驱动开发,但是麦克风的声音老是获取有问题
我对I2S和ES7210做了驱动开发,但是麦克风的声音老是获取有问题
i2s_chan_handle_t es7210_i2s_init(void)
ESP_LOGI(TAG, "Initializing I2S");i2s_chan_config_t chan_cfg = { .id = I2S_NUM_0, .role = I2S_ROLE_MASTER, .dma_desc_num = 8, // 增加 DMA 描述符数量 .dma_frame_num = 64, // 增加每个描述符的帧数 .auto_clear = false, // 不自动清除 DMA buffer }; ESP_ERROR_CHECK(i2s_new_channel(&chan_cfg, NULL, &i2s_rx_chan)); i2s_std_config_t std_cfg = { .clk_cfg = { .sample_rate_hz = SAMPLE_RATE, .clk_src = I2S_CLK_SRC_PLL_160M, // 明确指定时钟源 .mclk_multiple = I2S_MCLK_MULTIPLE_512, // 提高MCLK倍数以适应48kHz }, .slot_cfg = { .data_bit_width = I2S_DATA_BIT_WIDTH_16BIT, .slot_bit_width = I2S_SLOT_BIT_WIDTH_16BIT, .slot_mode = I2S_SLOT_MODE_STEREO, .slot_mask = I2S_STD_SLOT_BOTH, .ws_width = 16, .ws_pol = false, .bit_shift = true, .left_align = false, .big_endian = false, .bit_order_lsb = false, }, .gpio_cfg = { .mclk = MCLK_PIN, .bclk = ADC_BCLK_PIN, .ws = ADC_LRCLK_PIN, .dout = GPIO_NUM_NC, .din = ADC_DATA_PIN, .invert_flags = { .mclk_inv = false, .bclk_inv = false, .ws_inv = false, }, }, }; ESP_ERROR_CHECK(i2s_channel_init_std_mode(i2s_rx_chan, &std_cfg)); // 在启用通道之前添加延迟 vTaskDelay(pdMS_TO_TICKS(100)); ESP_ERROR_CHECK(i2s_channel_enable(i2s_rx_chan)); // 等待 I2S 稳定 vTaskDelay(pdMS_TO_TICKS(100)); ESP_LOGI(TAG, "I2S initialized successfully"); return i2s_rx_chan;}
void es7210_codec_init(void)
ESP_LOGI(TAG, "Init I2C used to configure ES7210");
i2c_config_t i2c_conf = {
.mode = I2C_MODE_MASTER,
.sda_io_num = GPIO_NUM_12,
.scl_io_num = GPIO_NUM_11,
.sda_pullup_en = GPIO_PULLUP_ENABLE,
.scl_pullup_en = GPIO_PULLUP_ENABLE,
.master = {
.clk_speed = EXAMPLE_ES7210_I2C_CLK,
ESP_ERROR_CHECK(i2c_param_config(EXAMPLE_I2C_NUM, &i2c_conf));
ESP_ERROR_CHECK(i2c_driver_install(EXAMPLE_I2C_NUM, i2c_conf.mode, 0, 0, 0));/* Create ES7210 device handle */ es7210_dev_handle_t es7210_handle = NULL; es7210_i2c_config_t es7210_i2c_conf = { .i2c_port = EXAMPLE_I2C_NUM, .i2c_addr = EXAMPLE_ES7210_I2C_ADDR }; ESP_ERROR_CHECK(es7210_new_codec(&es7210_i2c_conf, &es7210_handle)); ESP_LOGI(TAG, "Configure ES7210 codec parameters"); es7210_codec_config_t codec_conf = { .sample_rate_hz = EXAMPLE_I2S_SAMPLE_RATE, .mclk_ratio = EXAMPLE_I2S_MCLK_MULTIPLE, .i2s_format = EXAMPLE_I2S_TDM_FORMAT, .bit_width = (es7210_i2s_bits_t)EXAMPLE_I2S_SAMPLE_BITS, .mic_bias = EXAMPLE_ES7210_MIC_BIAS, .mic_gain = EXAMPLE_ES7210_MIC_GAIN, .flags = { .tdm_enable = 1 }, }; ESP_ERROR_CHECK(es7210_config_codec(es7210_handle, &codec_conf)); ESP_ERROR_CHECK(es7210_config_volume(es7210_handle, EXAMPLE_ES7210_ADC_VOLUME));}
