    M5 stack paper stop storing data in preferences?
    PRODUCTS
    1.1k
    • ScheduleDisplayS
      ScheduleDisplay
      I am using Preferences.h to store data on my M5 Stack Paper, such as Wi-Fi credentials, during my application's setup. It was working fine.
      During development and testing, I have rewritten the data in Preferences multiple times on this device. However, I recently noticed that new data is no longer being stored in Preferences, even though there is still available space, as confirmed by running the following code.
      #include <Preferences.h>
      void checkWifiCredentialsAndDecide(){
        preferences.begin("wifiCredentials", false);
       if(debugFlag){
          size_t whatsLeft = preferences.freeEntries();
          Serial.printf("Available enteries in the namespace table.\n" );
          Serial.println(whatsLeft);
          preferences.putString("test1", "test 1 value");
          Serial.println("preferences.getString(test1): " + String(preferences.getString("test1", "Default value")));
      Output
      127
      preferences.getString(test1): Default value // I am expecting to see "test 1 value"
      I have read that the NVS (Non-Volatile Storage) has a write cycle limitation of approximately 10,000 to 100,000 cycles.
      I have a few questions:
      Is there a way to check how many write cycles are remaining?
      Can I check if my flash memory is healthy or corrupted?
      Is it possible that the flash memory of my M5 Stack Paper has worn out?
      Thank you
