    Google maps bad request
    UiFlow 2.0
    • J
      JensH
      Hi All, I'm trying to get some details back from the Google maps API but it is coming back with a 400 bad request error when run on my M5 Paper. The URL works anywhere else I try it. Other URLs for other services work perfectly. Can anyone help with this code please.
      import os, sys, io
      import M5
      from M5 import *
      import requests2
      import network
      label0 = None
      http_req = None
      wlan = None
      mapsurl = None
      headers = None
      payload = None
      def getETA():
      global payload, headers, mapsurl, label0, wlan, http_req
      label0.setText(str('Label'))
      payload = {}
      headers = {}
      http_req = requests2.get(mapsurl, headers=headers, data=payload)
      label0.setText(str(http_req.text))
      def setup():
      global label0, http_req, wlan, mapsurl, headers, payload
      M5.begin()
      Widgets.fillScreen(0xeeeeee)
      label0 = Widgets.Label("label0", 20, 93, 1.0, 0x000000, 0xeeeeee, Widgets.FONTS.DejaVu24)
      wlan = network.WLAN(network.STA_IF)
      mapsurl = 'https://maps.googleapis.com/maps/api/distancematrix/json?origins=32 London Bridge St, London SE1 9SG&destinations=50 Lower Thames Street, London, EC3R 6DT&departure_time=now&key=<google maps api key>'
      wlan.connect('<Network SSID>', '<Network Password>')
      def loop():
      global label0, wlan, http_req, payload, headers, mapsurl
      M5.update()
      if BtnA.isPressed():
      getETA()
      if name == 'main':
      try:
      setup()
      while True:
      loop()
      try:
      print_error_msg(e)
      except ImportError:
      • J
        JensH
        Hi All, I was actually using a method that is a little old. This has now been replaced. I've fleshed this out a little more to show only the duration but the working code is below. Replacing 'routes.duration' with '*' will return the full trip including turn by turn.
        import os, sys, io
        import M5
        from M5 import *
        import requests2
        import network
        import json
        import requests
        import math
        rect0 = None
        label1 = None
        label0 = None
        http_req = None
        wlan = None
        url = None
        responsejson = None
        timeseconds = None
        sliced = None
        def getETA():
        global url, responsejson, timeseconds, label0, rect0, label1, http_req, wlan, sliced
        payload = json.dumps({
        "origin": {
        "address": "32 London Bridge St, London SE1 9SG"
        "destination": {
        "address": "50 Lower Thames Street, London, EC3R 6DT"
        "routingPreference": "TRAFFIC_AWARE"
        headers = {
        'X-Goog-FieldMask': 'routes.duration',
        'Content-Type': 'application/json',
        'X-Goog-Api-Key': '{{GMP API Key}}'
        response = requests.request("POST", url, headers=headers, data=payload)
        responsejson = json.loads((response.text))
        timeseconds = responsejson["routes"][0]["duration"]
        #sliced = slice(0,4)
        #print(timeseconds[slice(4)])
        print(str(math.trunc(int(timeseconds.strip("s"))/60)) + "m" )
        label0.setText(str(math.trunc(int(timeseconds.strip("s"))/60)) + "m" )
        def setup():
        global label0, rect0, label1, http_req, wlan, url, timeseconds, responsejson, sliced
        M5.begin()
        label0 = Widgets.Label("Start", 317, 99, 1.0, 0x000000, 0xeeeeee, Widgets.FONTS.DejaVu72)
        rect0 = Widgets.Rectangle(301, 52, 199, 199, 0x000000, 0xeeeeee)
        label1 = Widgets.Label("Pitacs ETA", 336, 207, 1.0, 0x000000, 0xeeeeee, Widgets.FONTS.DejaVu24)
        url = 'https://routes.googleapis.com/directions/v2:computeRoutes?key=<google maps api key>'
        def loop():
        M5.update()
        getETA()
        if name == 'main':
        try:
        setup()
        while True:
        loop()
        try:
        print_error_msg(e)
        except ImportError:
