IMU Pro Mini Unit fails to Init on Core2
Summary
Using a U171 IMU Pro Mini with Core2, the U171 fails to initialize, returning error:OSError: [Errno 19] ENODEVRepro Steps
Initialize the bus and U171
i2c0 = I2C(0, scl=Pin(33), sda=Pin(32), freq=100000) print(i2c0.scan()) imupro_0 = IMUProUnit(i2c0)i2c0.scan()returns BMI270 (0x68) and BMP280 (0x76); the BMM150 is behind the BMI270.Trace for the constructor's failure is :
Traceback (most recent call last): File "main.py", line 24, in <module> File "main.py", line 17, in setup File "unit/imu_pro.py", line 36, in __init__ File "driver/bmi270_bmm150.py", line 720, in __init__ File "driver/bmi270_bmm150.py", line 539, in __init__ File "driver/bmi270_bmm150.py", line 622, in _write_reg OSError: [Errno 19] ENODEVLooking at the underlying code :
Constructor calls:
super().__init__(i2c, address=bmi270_address, aux_address=address)Which does a soft reset, then attempts to write a register:
# Perform initialization sequence. # 0.Soft-reset self.soft_reset() # 1.Disable power save mode. self._write_reg(PWR_CONF, 0x00) time.sleep_ms(10)The write fails:
self._i2c.writeto_mem(self.address, reg, val)I patched the following and added
i2c0.scan()after each i2c write:IMUProUnit.soft_reset IMUProUnit._write_reg IMUProUnit.new_write_burstScanning the bus after each write, stops the ENODEV error. However
initnever completes.Any ideas how to get U171 to work?
@ChrisFSB Any ideas here folks? Thx!
