    M5 touch wakeup read coordinates
    General
    821
    • C
      cthulu
      Hi, I am trying to update my weatherapp (modified from an open source project) to wake up when the screen is touched. I want to read the coordinates after the wakeup, do something, and go back to deep sleep (for 1hr).
      My proto-code is something like this
      #include <M5EPD.h>
      M5EPD_Canvas canvas(&M5.EPD);
      int x, y= 0;
      void setup()
         M5.EPD.SetRotation(0);
         M5.EPD.Clear(true);
         canvas.createCanvas(960, 540);
         canvas.setTextSize(5);
         canvas.drawString("Touch The Screen!", 400, 20);
         canvas.pushCanvas(0, 0, UPDATE_MODE_DU4);
      void loop()
         if (M5.TP.available() || esp_sleep_get_wakeup_cause() == ESP_SLEEP_WAKEUP_TOUCHPAD)
            M5.TP.update();
            tp_finger_t fingerItem = M5.TP.readFinger(0);
            x = fingerItem.x;
            y = fingerItem.y;
            canvas.drawFloat(x, 0, 400, 60);
            canvas.drawFloat(y, 0, 400, 60);
         // Clear out all previous touch screen interrupts
         while(digitalRead(GPIO_NUM_36) == LOW)
            M5.TP.flush();
            delay(10);
         Serial.println("before sleep");
         Serial.flush();
         delay(1000);
         // Enable timer (3600 s)
         esp_sleep_enable_timer_wakeup(3600 * 1000000UL);
         esp_sleep_enable_ext0_wakeup(GPIO_NUM_36, LOW);
         gpio_hold_en((gpio_num_t) M5EPD_MAIN_PWR_PIN);
         gpio_deep_sleep_hold_en();
         esp_deep_sleep_start();
         // Only reached after light sleep
         Serial.println("after sleep");
         delay(1000);
      Not sure this is the right way as I could not find any specific way to read the touch coordinates.
        felmue @cthulu
        Hello @cthulu
        you want to check against ESP_SLEEP_WAKEUP_EXT0 as wake-up cause since the touch interrupt line (GPIO36) is setup using esp_sleep_enable_ext0_wakeup().
        BTW: ESP_SLEEP_WAKEUP_TOUCHPAD is meant for an ESP32 feature where a GPIO can act as a touch sensor. See here (Which is different from the touch screen).
        • C
          cthulu @felmue
          Thanks @felmue!
          I will change that. Regarding reading the touch location, is that the proper way? First M5.TP.update() and then trying to clear the interrupt using M5.TP.flush()?
          I am trying render some buttons on the screen and then go to deep sleep, waiting for the touch push.
          • C
            cthulu @cthulu
            Looks like the code, with the modification you've suggested works! I can get the coordinates of the touch that lead to the wake up of the M5. Thanks!
