    Blynk on M5Stack via uiFlow and block-maker
    PROJECTS
    5
    32
    144.8k
    • world101W
      world101
      I've been playing around with block-maker.m5stack.com quite a bit the past few days. I managed to integrate the Blynk python library and a few of the examples from the Blynk github repo.
      Here is how I did it. I'm on a Mac, so sorry I don't have the equivalent instructions for a PC.
      • First you need to get the BlynkLib library on the M5Stack. Clone the repo to your computer (or just download the BlynkLib.py file from github.com)
        git clone https://github.com/vshymanskyy/blynk-library-python.git
      • You will also need ampy or another file transfer utility to copy BlynkLib.py to the M5Stack. Follow the instructions in this video.
        https://www.youtube.com/watch?v=rvP3GixWG1Y
      • Copy BlynkLib.py to the M5Stack and put it into the /flash/lib directory so it can be imported as a MicroPython module
        cd blynk-library-python
        ampy -p /dev/tty.SLAB_USBtoUART -b 115200 put BlynkLib.py /flash/lib/BlynkLib.py
        Note: if you use a local Blynk server like I do, you can edit line 216 of BlynkLib.py and change it to your local server IP and port. Don't forget to put the updated file on your m5stack with ampy. This is the line to edit:
        self.conn.connect(socket.getaddrinfo("blynk-cloud.com", 80)[0][4])
      • Using your browser, go to flow.m5stack.com. Open this *.m5b file that I made with block-maker.m5stack.com. It has the custom blocks that I created for Blynk.
      • Open this Blynk flow by using the Open option in the upper right menu.
      • Load the image Blynk_m5.jpg into the Resource Manager (upper right menu of uiFlow)
        Note: you may need to reload the image on the UI
      Now it should look like this:
      • Open the Blynk app on your iOS or Android mobile device. Create a new project and give it a name (I called my project MicroPython). Obtain the auth token from the nut icon in the upper right corner.
      • Drag 4 widgets into the project view
      1. Value Display: set title to "Uptime (sec)", set pin to V0, and set Refresh Interval to 1 sec
      2. Horizontal or Vertical Slider: set pin to V1 and Decimals to #
      3. Button: set title "Push Notification", set pin to V2, set ON label to Sent and set OFF label to Send
      4. Notification: no settings necessary
      • Press the Run icon (triangle in upper right corner of the Blynk app)
      • Back on your browser, paste your auth token into the flow under the Blynk init block
      • Press the Run icon (triangle in upper right corner of the uiFlow page) and wait for the Blynk app to connect to the M5Stack. Optionally, you can Download the flow to your m5stack using the Download option in the upper right menu.
      Demo Use Cases:
      1. M5Stack uptime (in seconds) will be shown on the Blynk app and on the M5Stack LCD
      2. Change the Slider and the value will be updated on the M5Stack LCD
      3. Tap the Push Notification button and it should send a push notification to the Blynk app on your device with the text shown in the flow.
      Happy Blynking with your M5Stack! :-)
        Nice one, well done and thanks for the writeup!
        What is ampy?
        • world101W
          world101 @ajb2k3
          @ajb2k3 said in Blynk on M5Stack via uiFlow and block-maker:
          What is ampy?
          It stands for Adafruit MicroPython tool. I recommend watching the video that I linked to above.
            ajb2k3 @world101
            @world101
            Thanks.
            • L
              LastCaress
              Blynk and m5stack is an awesome combination! I will be watching this thread!
              • L
                LastCaress
                Tried this and got AttributeError "module object has no attribute blynk" :|
                • world101W
                  world101 @LastCaress
                  @lastcaress said in Blynk on M5Stack via uiFlow and block-maker:
                  Not sure exactly where it failed for you. Can you provide more detail on how far you got before seeing the error?
                  • L
                    LastCaress @world101
                    @world101 I managed to copy the blinklyb file to the m5stack, and the m5f and m5b files you provided. I think this error refers to :
                    blynk = BlynkLib.Blynk(BLYNK_AUTH)
                    I don't think it understands this line!
                    • L
                      LastCaress
                      It manages to import the library, it just doesn't understand that attribute!
                      • world101W
                        @lastcaress
                        If it doesn’t understand that line it may not have imported the library correctly. Did you put it in the /flash/lib directory on the m5stack? Also, just wanted to make sure you are running the latest v1.1.2 firmware.
                        Did you paste your Blynk Auth Key into the flow before running it in uiFlow?
                        Also, are you able to access the REPL prompt? If not I can show you how. It’s good for troubleshooting.
                        • L
                          LastCaress
                          I am running the latest firmware and I uploaded the BlynkLib.py file from the git repo you linked using rshell to /flash/lib :P I used a raspbian os to it as I've never been able to use ampy! The import BlynkLib line of code doesn't cause any error. I did paste the auth key :D
                          I do not know how to access the repl prompt though!
                          • L
                            LastCaress
                            So I got hold of a macbook and tried via ampy and.. it works!! I should've tried this before as my attemps at using the blynk python library probably didn't work before because I used rshell and maybe it sends the file in a different format? This is very nice!
                              ajb2k3 @LastCaress
                              Ampy didn't work on my macbook pro and it took me ages to find out that my pythone was P3 but I hadn't set up the enviroment shell correctly.
                              Glad it works.
                                Sweet, I got this to work as well.
                                Looks like something else to add to the project list.
                                • world101W
                                  world101
                                  @ajb2k3, @LastCaress
                                  Glad you all got it working. To access REPL, you can do this from the Mac Terminal with the M5Stack connected to a USB port.
                                  screen /dev/tty.SLAB_USBtoUART 115200
                                  You may not see anything at first, so you can press CTRL+C on the keyboard to drop you into the REPL prompt (>>>). From there, you can do your regular MicroPython commands. For example...
                                  >>> os.listdir()
                                  ['image_app', 'main.py', 'emoji', 'sys_lib', 'config.py', 'lib', 'res', 'flow.py', 'blocks', 'apps', 'debug.py', 'modeconfig.json', 'boot.py', 'img']
                                  >>> os.listdir('lib')
                                  ['servo.py', 'square.py', 'step_motor.py', 'm5_pin.py', 'm5bala.py', 'wave.mpy', 'lego_board.py', 'bmp280.mpy', 'dht12.mpy', 'mpu6050.py', 'chunk.mpy', 'pid.py', 'lego.py', 'BlynkLib.py']
                                  >>> import BlynkLib
                                      ___  __          __
                                     / _ )/ /_ _____  / /__
                                    / _  / / // / _ \/  '_/
                                   /____/_/\_, /_//_/_/\_\
                                          /___/ for Python v0.2.0
                                  >>> help()
                                  Welcome to LoBo MicroPython for the ESP32
                                  For online documentation please visit the Wiki pages:
                                  https://github.com/loboris/MicroPython_ESP32_psRAM_LoBo/wiki
                                  Based on official MicroPython, this port brings many new features:
                                   - support for two cores and 4MB SPIRAM (psRAM)
                                   - improved 'network' module
                                   - greatly improved thread support
                                   - support for 3 different internal file systems on top of ESP32 VFS
                                   - ESP32 native support for SD Card
                                   - built-in FTP & Telnet servers
                                   - support for OTA updates
                                   - many new and improved hardware access modules implemented in C
                                   and many more...
                                  Control commands:
                                    CTRL-A        -- on a blank line, enter raw REPL mode
                                    CTRL-B        -- on a blank line, enter normal REPL mode
                                    CTRL-C        -- interrupt a running program
                                    CTRL-D        -- on a blank line, do a soft reset of the board
                                    CTRL-E        -- on a blank line, enter paste mode
                                  For further help on a specific object, type help(obj)
                                  For a list of available modules, type help('modules')
                                  >>> help('modules')
                                  __main__          m5flow/m5mqtt     math              uerrno
                                  _thread           m5flow/m5stack    microWebSocket    uhashlib
                                  ak8963            m5flow/peripheral microWebSrv       uheapq
                                  array             m5flow/simple     microWebTemplate  uio
                                  binascii          m5flow/ubutton    micropython       ujson
                                  btree             m5flow/unit/adc   mpu6500           uos
                                  builtins          m5flow/unit/button                  mpu9250           upip
                                  cmath             m5flow/unit/color network           upip_utarfile
                                  collections       m5flow/unit/dac   os                upysh
                                  display           m5flow/unit/dual_button             pye               urandom
                                  errno             m5flow/unit/ext_io                  random            ure
                                  freesans20        m5flow/unit/ir    re                urequests
                                  functools         m5flow/unit/ncir  select            uselect
                                  gc                m5flow/unit/relay socket            usocket
                                  hashlib           m5flow/unit/rgb_  ssd1306           ussl
                                  heapq             m5flow/unit/tof   ssl               ustruct
                                  io                m5flow/units      struct            utime
                                  json              m5flow/utils      sys               utimeq
                                  logging           m5flow/wifichoose time              uzlib
                                  m5base            m5flow/wificonfig tpcalib           websocket
                                  m5flow/app_manage m5flow/wifisetup  ubinascii         writer
                                  m5flow/i2c_bus    m5ui              ucollections      ymodem
                                  m5flow/m5cloud    machine           uctypes           zlib
                                  Plus any modules on the filesystem
                                  etc...
                                  Or if you don't go into the REPL prompt, but still have the screen session connected, you can see the serial logs from the m5stack. Reboot the M5stack and you should see the Blynk start up, plus some other useful information (network connection, connection to M5cloud, etc.).
                                  To exit the screen session press CTRL+A then CTRL+\ then y.
                                  • world101W
                                    world101
                                    By the way, I haven't found a way to import existing m5b files into block-maker.m5stack.com, so here are the ones I created. Feel free to play around with them and even create some new ones! The official Blynk colors are here: http://docs.blynk.cc/#blynk-main-operations-change-widget-properties
                                    Blynk Init:
                                    import BlynkLib
                                    BLYNK_AUTH = ${auth_token}
                                    Blynk Run:
                                    blynk.run()
                                    Uptime:
                                    @blynk.VIRTUAL_READ(${pin})
                                    def v${pin}_read_handler():
                                        time_val = time.ticks_ms() // 1000
                                        blynk.virtual_write(${pin}, time_val)
                                        lcd.textClear(${x}, ${y}, '      ', lcd.${bg_color})
                                        lcd.print(time_val, ${x}, ${y}, lcd.${fg_color})
                                    Slider: (Note, this is slightly different than the tutorial above. I was experimenting with passing a variable into the block. Feel free to adjust it as needed)
                                    @blynk.VIRTUAL_WRITE(${pin})
                                    def v${pin}_write_handler(value):
                                        ${variable} = '{}'.format(value).strip("['']")
                                        lcd.print(${variable}, ${x}, ${y}, lcd.${fg_color}, transparent=True, fixedwidth=True)
                                    Push Notification:
                                        if value:
                                            blynk.notify(${text})
                                    I'm really interested in how to link blocks together, like the m5stack team did for the MQTT blocks. But I'll start a new thread on that soon.
                                      Can you pm me your real name as I would like to credit you in my book for all the hard work on M5Blynk
                                      • K
                                        kmo
                                        Very cool! Can't wait to try it out!
                                        • world101W
                                          world101
                                          I just noticed the Blynk developers released a new version 0.2.0 of blynk-library-python on git hub. I seems to have some additional advanced features like
                                          • debug logging
                                          • custom server
                                          • changing heartbeat
                                          • connected/disconnected events
                                          • generic virtual pin events
                                          • BlynkTimer
                                          I have not tried this out yet, but plan to in the next week or so. In case you wanted to try the older version of the library, here is the commit:
                                          https://github.com/vshymanskyy/blynk-library-python/commit/4cbf641fade72a11e797436a8656ebf28f239801
                                            ajb2k3 @world101
                                            @world101 I managed to build a private server on Saturday but having auto startup issues.
                                            I’ve tried the guide but still have to manually start the server
