    Heart rate and NCIR competition core2
    Core 2
      mromandmonnier
      Hi all,
      I am working on a core 2 v1 module with a NCIR and a heart rate module connected by a grove hub and they both work perfectly fine individually (when only one is plugged in and when they are both plugged in) : whatever the first one I select, it works perfectly but when I want to switch from getting data from the heart rate module to the NCIR module, (or NCIR to heart rate), everything freezes.
      Here is my code if it helps:
      rom m5stack import *
      from m5stack_ui import *
      from m5ui import *
      from uiflow import *
      import time
      import wifiCfg
      import urequests
      import unit
      INITIATE
      screen = M5Screen()
      screen.clean_screen()
      ncir2 = unit.get(unit.NCIR, unit.PORTA)
      heart = unit.get(unit.HEART, unit.PORTA)
      heart.setLedCurrent(0x04, 0x01)
      heart.setMode(0x03) # HR & SpO2
      set_record = 0
      wifiCfg.autoConnect(lcdShow=False)
      LABELS
      instructions1 = M5Label('Posez votre index gauche sur le capteur', x=15, y=10, color=0xbc0c21, font=FONT_MONT_14, parent=None) # y+15 between lines
      HeartRate = M5Label('Heart', x=15, y=114, color=0x509ed3, font=FONT_MONT_30, parent=None)
      sp = M5Label('SpO2', x=129, y=114, color=0x509ed3, font=FONT_MONT_30, parent=None)
      temperature_label = M5Label('Temp', x=229, y=114, color=0x509ed3, font=FONT_MONT_30, parent=None)
      IMAGES
      image_oxy = M5Img("res/oximeter.png", x=133, y=46, parent=None)
      image_pulse = M5Img("res/pulse.png", x=20, y=46, parent=None)
      image_thermo = M5Img("res/thermometer.png", x=238, y=46, parent=None)
      radius = 20
      green 0x33b151
      red 0xb10707
      button_cardiac = M5Btn(text='O', x=120, y=200, w=radius, h=radius, bg_c=0xb10707, text_c=0xFFFFFF, font=FONT_MONT_14, parent=None)
      button_temp = M5Btn(text='O', x=170, y=200, w=radius, h=radius, bg_c=0xb10707, text_c=0xFFFFFF, font=FONT_MONT_14, parent=None)
      def button_cardiac_pressed():
      global set_record
      button_cardiac = M5Btn(text='I', x=120, y=200, w=radius, h=radius, bg_c=0x33b151, text_c=0xFFFFFF, font=FONT_MONT_14, parent=None)
      set_record = 1
      pass
      button_cardiac.pressed(button_cardiac_pressed)
      def button_temp_pressed():
      global set_record
      button_temp = M5Btn(text='I', x=170, y=200, w=radius, h=radius, bg_c=0x33b151, text_c=0xFFFFFF, font=FONT_MONT_14, parent=None)
      set_record = 2
      pass
      button_temp.pressed(button_temp_pressed)
      while True:
      if set_record == 1:
          # HR
          hr = int(heart.getHeartRate()/3)
          HeartRate.set_text(str(hr))
          label_heart_value = M5Label('bpm', x=70,  y=125, color=0x509ed3, font=FONT_MONT_14, parent=None)
          # O2 SAT
          delta = 5
          spo2 = heart.getSpO2()+delta
          if spo2 > 100:
              spo2 = 100
          elif spo2 == delta:
              spo2 = 0
          sp.set_text(str(spo2))
          label_spo2_value  = M5Label('%', x=180, y=120, color=0x509ed3, font=FONT_MONT_14, parent=None)
          wait(1)
          pass
      elif set_record == 2:
          temperature = ncir2.temperature
          wait(0.2)
          temperature_label.set_text(str(temperature))
          label_temp_value  = M5Label('°C',  x=300, y=125, color=0x509ed3, font=FONT_MONT_14, parent=None)
          wait(1)
          pass
      Thank you so much for your help!
        mromandmonnier @mromandmonnier
        Hi all,
        I have been looking for the answer to my problem and my best guest might be the fact that they both are using PortA, thus the competition.
        Is there a way to switch from one sensor to another to get a reading from both?
        Thank you in advance :)
