    Controller that can be powered with 5v through GROVE
    5 Posts 2 Posters 3.0k Views
      amateur58
      I'm looking for a controller that accepts 5v through GROVE. This is to use it with a heat pump that sends 5v over the 5v line. I know the Atom S3 Lite does. I would be particularly interested in either the M5stickC Plus 2 and the Nano C6. Now I have some basic knowledge of schematics but I can't decide wether these can be powered over GROVE. I looked up all schematics.
      Atom S3 Lite schematics
      M5StickC Plus2 schematics
      Nano C6 schematics
      I can't read the schematics well enough to decide wether the Stick and Nano can be powered over GROVE. If I look at the Atom S3 Lite schematics I see the GROVE port is wired differently. But that's all I can conclude. It would be great if anyone could help me in wether the Stick and Nano are fit for my purpose and how you came to that conclusion so I can learn from it. Thanks!
        felmue @amateur58
        Hello @amateur58
        as you already found out M5AtomS3 can be powered via 5 V through Grove. The same is true for M5NanoC6 as VBUS (from USB-C) is connected to 5 V of the Groove port.
        However M5StickCPlus2 is different as it has a dedicated 5 V IN and 5 V OUT. It can only be powered via 5 V IN (which is not on the Grove port).
          amateur58 @felmue
          Thanks! How did you see that in the schematic for the M5StickC Plus2?
            felmue @amateur58
            Hi @amateur58
            you need to open the PDF of the schematic, else you don't see all of it. +5VOUT going to the Grove port comes out of U6 going through diode D20. So if you were to feed 5 V to the Grove port it would end at the diode.
            A 1 Reply Last reply Reply Quote 2
              amateur58 @felmue
              @felmue Thank you! I learned something today by downloading the PDF's and applying what you explained :)
