    M5Unified 0.2.3 broken on PaperS3
    SOFTWARE
    771
    • W
      wsanders
      My sketches all fail to compile. I am using the 1.8.19 IDE on Linux, haven't moved to the 2.0 IDE yet :
      Arduino: 1.8.19 (Linux), Board: "M5PaperS3, Disabled, OPI PSRAM, QIO 80MHz, 16MB (128Mb), Core 1, Core 1, Hardware CDC and JTAG, Enabled, Disabled, Disabled, UART0 / Hardware CDC, 16M Flash (3MB APP/9.9MB FATFS), 240MHz (WiFi), 921600, None, Disabled"
      In file included from /home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.h:5,
                       from /home/wsanders/Documents/ArduinoSketchbook/M5/badgeWX/badgeWX.ino:2:
      /home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.hpp: In member function 'virtual void m5::M5Unified::begin(m5::M5Unified::config_t)':
      /home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.hpp:326:62: error: no matching function for call to 'm5gfx::M5GFX::init_without_reset(bool&)'
             bool res = Display.init_without_reset(cfg.clear_display);
      In file included from /home/wsanders/Documents/ArduinoSketchbook/libraries/M5GFX/src/M5GFX.h:22,
                       from /home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.hpp:19,
      /home/wsanders/Documents/ArduinoSketchbook/libraries/M5GFX/src/lgfx/v1/LGFXBase.hpp:1411:10: note: candidate: 'bool lgfx::v1::LGFX_Device::init_without_reset()'
           bool init_without_reset(void) { return init_impl(false, false); };
      /home/wsanders/Documents/ArduinoSketchbook/libraries/M5GFX/src/lgfx/v1/LGFXBase.hpp:1411:10: note:   candidate expects 0 arguments, 1 provided
       Used: /home/wsanders/.arduino15/packages/m5stack/hardware/esp32/2.1.3/libraries/WiFi
       Not used: /home/wsanders/arduino-1.8.19-NOSAVE/libraries/WiFi
      exit status 1
      With 0.2.2 I needed to use these includes, in this order:
      #include <epdiy.h>
      #include <M5Unified.h>
      Maybe this has changed? Here's some sample code, it compiles with 0.2.2:
      #include <epdiy.h>
      static constexpr const char* state_name[16] =
      { "none"
          , "touch"
          , "touch_end"
          , "touch_begin"
          , "___"
          , "hold"
          , "hold_end"
          , "hold_begin"
          , "___"
          , "flick"
          , "flick_end"
          , "flick_begin"
          , "___"
          , "drag"
          , "drag_end"
          , "drag_begin"
      void setup(void)
        Serial.begin(115200);
        M5.Display.setRotation(M5.Display.getRotation() ^ 2);
        M5.Display.setEpdMode(epd_mode_t::epd_fastest);
        M5.Display.startWrite();
        M5.Display.setTextSize(2);
      void loop(void)
        // too slow! M5.delay(10);
        M5.delay(2);
        M5.update();
        // Count is going to be the bumber of "fingers" detected: 0, 1, max 2
        // So, can be ignored for simple button press
        // Always seems to be 0 inside for loop?
        // auto count = M5.Touch.getCount();
        auto t = M5.Touch.getDetail(0);
        if (t.state > 0) {
        // State is state of the entire touch screen
        // All we care about is t.wasFlicked
            Serial.print(t.state);
            Serial.println(state_name[t.state]);
        M5.Display.display();
        felmue @wsanders
        Hello @wsanders
        the error indicates that M5GFX library is out of date. Did you update M5GFX library to the latest as well?
        • W
          wsanders @felmue
          Still a problem:
          /home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp: In static member function 'static bool m5::M5Unified::_speaker_enabled_cb_atomic_echo(void*, bool)':
          /home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp:338:10: error: variable 'spk_cfg' set but not used [-Werror=unused-but-set-variable]
               auto spk_cfg = self->Speaker.config();
          /home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp: In static member function 'static bool m5::M5Unified::_microphone_enabled_cb_atomic_echo(void*, bool)':
          /home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp:441:10: error: variable 'spk_cfg' set but not used [-Werror=unused-but-set-variable]
          cc1plus: some warnings being treated as errors
          exit status 1
          Error compiling for board M5PaperS3.
          M5GFX is now 0.2.5, M5United is 0.2.3, this bug comes from M5United, upgraded M5GFX is OK.
          Too busy today to file a bug report on this, later.
            felmue @wsanders
            Hello @wsanders
            I think these compiler error have been fixed (see here), but after tagging the library. I guess it will be in M5Unified 0.2.4.
