    M5Stack Core S3 Access to SDCARD Micropython
    2 Posts 1 Posters 2.0k Views 1 Watching
    • L Offline
      LordInchcape
      Can someone point me at some example code to access the SDCard in Core S3 using micropython?
      Last year there were several discussion topics, I suspect it works. Just need a sample.
      • L Offline
        LordInchcape @LordInchcape
        @LordInchcape Using M5CoreS3_SDCard_read_dir_UIFlow2.0.4 the following micropython will work:-
        *import machine
        import os
        card = machine.SDCard(slot=2, sck=36, miso=35, mosi=37, cs=4, freq=1000000)
        os.mount(card,"/sd")
        print(os.listdir("/sd"))
        f = open("/sd/test.txt", "w")
        f.write("Hello world\r\n")
        f.close()
        g = open("/sd/test.txt", "r")
        print(g.read())
        g.close()
        os.unlink("/sd/test.txt")**
        Still to determine if it treads on something else.
