    M5.Power.getBatteryLevel() returns 0 when using Power.lightSleep etc.
    1 Posts 1 Posters 1.0k Views
    • L Offline
      larrygzone
      I would appreciate any thoughts on this.
      M5.Power.getBatteryLevel() works fine on Capsule. But when I use power saving, such as Power.lightSleep(6000000), M5.Power.getBatteryLevel() returns 0. Same results with .deepSleep(6000000).
      The Sleep works as expected, but M5.Power.getBatteryLevel() always returns zero when any "Sleep" is used.
      Full code I use is below:
      Using M5Capsule to gather ENVIII sensor data. Then send via to Paper S3 via
      WiFi.
      #include <M5Capsule.h>
      #include <esp_now.h>
      #include <WiFi.h>
      #include <M5UnitENV.h>
      SHT3X sht3x;
      QMP6988 qmp;
      uint8_t broadcastAddress[] = {0xa0, 0x85, 0xe3, 0xef, 0xf4, 0x48};
      // Structure example to send data
      // Must match the receiver structure
      typedef struct struct_message {
      //char a[32];
      float Mytemp;
      int Myhum;
      int Mypres;
      float Myalt;
      int Mysendbat;
      //bool d;
      } struct_message;
      // Create a struct_message called myData
      struct_message myData;
      esp_now_peer_info_t peerInfo;
      // callback when data is sent
      void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
      Serial.print("\r\nLast Packet Send Status:\t");
      Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
      auto cfg = M5.config();
      M5Capsule.begin(cfg);
      M5.Power.begin();
      Serial.begin(115200);
      //Config the ENVIII Sensor
      if (!qmp.begin(&Wire, QMP6988_SLAVE_ADDRESS_L, 13, 15, 400000U)) {
      Serial.println("Couldn't find QMP6988");
      while (1) delay(1);
      if (!sht3x.begin(&Wire, SHT3X_I2C_ADDR, 13, 15, 400000U)) {
          Serial.println("Couldn't find SHT3X");
          while (1) delay(1);
      // Set device as a Wi-Fi Station
      WiFi.mode(WIFI_STA);
      // Init ESP-NOW
      if (esp_now_init() != ESP_OK) {
      Serial.println("Error initializing ESP-NOW");
      return;
      // Once ESPNow is successfully Init, we will register for Send CB to
      // get the status of Trasnmitted packet
      esp_now_register_send_cb(OnDataSent);
      // Register peer
      memcpy(peerInfo.peer_addr, broadcastAddress, 6);
      peerInfo.channel = 0;
      peerInfo.encrypt = false;
      // Add peer
      if (esp_now_add_peer(&peerInfo) != ESP_OK){
      Serial.println("Failed to add peer");
      return;
      // Set values to send
      if (sht3x.update()) {
      Serial.println("-----SHT3X-----");
      Serial.print("Temperature: ");
      Serial.print(sht3x.cTemp);
      Serial.println(" degrees C");
      Serial.print("Humidity: ");
      Serial.print(sht3x.humidity);
      Serial.println("% rH");
      Serial.println("-------------\r\n");
      if (qmp.update()) {
          Serial.println("-----QMP6988-----");
          Serial.print(F("Temperature: "));
          Serial.print(((qmp.cTemp *(9/5)) + 32));
          Serial.println(" *C");
          Serial.print(F("Pressure: "));
          Serial.print(qmp.pressure);
          Serial.println(" Pa");
          Serial.print(F("Approx altitude: "));
          Serial.print(qmp.altitude);
          Serial.println(" m");
      myData.Mysendbat = M5.Power.getBatteryLevel();
      myData.Mytemp = sht3x.fTemp;
      myData.Myhum = sht3x.humidity;
      myData.Mypres = qmp.pressure;
      myData.Myalt = qmp.altitude;
      // Send message via ESP-NOW
      esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &myData, sizeof(myData));
      if (result == ESP_OK) {
      Serial.println("Sent with success");
      Serial.println(myData.Mytemp);
      Serial.println(myData.Mysendbat);
      else {
      Serial.println("Error sending the data");
      M5.Power.lightSleep(10000000);
