    Download program to the PaperS3
    4 Posts 2 Posters 2.5k Views
    • O Offline
      os-ronald
      I've just received the Paper S3.
      I created a program with just a print ‘Hello M5’. I can't manage to download this program to the device.
      The progress bar remains empty.
      I did flash the device with M5Burner and UIFlow2.0 PaperS3.
      I tested with another device, NanoC6. It does the job and the program runs.
      Do you have any ideas for solving the problem?
      Have you had this problem before? What solution did you find?
      Thanks in advance
        felmue @os-ronald
        Hello @os-ronald
        hmm, both options (Run and Download) work for me (via USB connection).
        Which UIFlow2 firmware version did you install on your M5PaperS3? I used v2.2.0-hotfix-2.
        • O Offline
          os-ronald
          Thanks Felix
          yes, I installed version 2.2.0-hotfix-2 on 2024-12-26.
          I plugged it in Usb. In the same way as with the NanoC6 which works.
          • O Offline
            os-ronald
            Well, I think I've made a beginner's mistake. I didn't restart PaperS3.
            After flashing it, I pressed the reset/boot/... button and it displayed the UiFlow page on PaperS3.
            Thanks for your help Felix
