    Can't get m5Dial to display an image loaded via UIFlow2
    SOFTWARE
    1.4k
    • J
      jeanfabre
      Hi Everyone :)
      Pulling my hairs on this. I just can't find any video tutorial actually showing UIFlow2 working when it comes to showing images on an M5Dial.
      Inside UIFlow , the images are showing fine, I can move them around in the UI, it all seems well and good, but as soon as I want to play or download onto the M5Dial, nothing is shown, I don't even get an error.
      I feel stuck. I have googled a lot on this matter and for sure tried many ways to export and save png, jps, bmp in vairous format and settings, and none is working. even on github projects that apparently got it to work on stick or other devices ( again... never found anything with a m5dial sadly...) it doesn't work neither, though, UIFlow is showing these images just fine.
      Any help would be very much appreciated!
      if you need screenshots of my UIFlow project UI or have questions, let me know.
      Thanks,
      Jean
      • J jeanfabre referenced this topic on
      • J
        jeanfabre @jeanfabre
        @jeanfabre @felmue, thanks for your answer on that other post (https://community.m5stack.com/post/26512) it works ! thanks for pointing out that! it's really odd that at least we have no errors in the terminal that the file was not found... coudl save a lot of frustration, or maybe there is a debug mode somwhere in uiflow to get more details out of the current code execution
