    CoreS3 and ENV Pro (BME688)
    7 Posts 3 Posters 4.3k Views 1 Watching
      aitech
      Hi
      I am trying to get an S3Core to read from an ENV Pro (BME688) but without success, I am suspecting either incompatibility or a dead sensor, it seems to be behaving like it is dead, it works the same when plugged in as not plugged in. Or is there something I need to switch on?
      Method1
      Firstly using Arduino I have used the code from https://github.com/m5stack/M5Unit-ENV/blob/master/examples/ENV_PRO/ENV_PRO.ino but am unable to get past line 57
       if (!envSensor.begin(BME68X_I2C_ADDR_HIGH, Wire)) {
              checkBsecStatus(envSensor);
      I have put some debug in and it just hits this and hangs on the serial output, if I take out this code then it carries on but obviously errors. I tried changing '_HIGH' to '_LOW' but it made no difference.
      Method2
      I loaded https://github.com/adafruit/Adafruit_BME680/blob/master/examples/bme680test/bme680test.ino
      I can't get it to go past line 39
      if (!bme.begin()) {
          Serial.println("Could not find a valid BME680 sensor, check wiring!");
          while (1);
      It just displays the error message and hangs.
      Jon
        felmue @aitech
        Hello @aitech
        did you adjust SDA and SCL accordingly? The example is for M5Core which uses different GPIOs on port A (red) than M5CoreS3.
        Try changing this line:
        Wire.begin(21, 22);
        to
        Wire.begin(2, 1);
        You can also try the I2C scanner (internal and port A) from here.
        A 2 Replies Last reply Reply Quote 1
          aitech @felmue
          Hello @felmue
          Many thanks, yes I did have the wrong settings for SDA and SCL, I have now corrected them and am getting more output as below, but am getting error code -2, and then its rebooting.
          Am investigating further.......
          BME68X error code : -2
          Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
          Core 1 register dump:
          PC : 0x40056f5c PS : 0x00060630 A0 : 0x82016254 A1 : 0x3fceb8e0
          A2 : 0x3fceb8f0 A3 : 0x000009b0 A4 : 0x0000002e A5 : 0x3fceb8f0
          A6 : 0x00060023 A7 : 0x00000002 A8 : 0x00000000 A9 : 0x00060023
          A10 : 0x00060023 A11 : 0x00000001 A12 : 0x8037dbfd A13 : 0x3fc93bf0
          A14 : 0x00060023 A15 : 0x00000003 SAR : 0x0000001e EXCCAUSE: 0x0000001c
          EXCVADDR: 0x000009b0 LBEG : 0x40056f5c LEND : 0x40056f72 LCOUNT : 0x00000001
          Backtrace: 0x40056f59:0x3fceb8e0 |<-CORRUPTED
          ELF file SHA256: a0a73cde460324f4
          Thanks for the link to the scanner I will try that as well.
            aitech @felmue
            Nothing showing on the scanner, so looks like a dead sensor.
            felmueF LuftwaffleL 2 Replies Last reply Reply Quote 0
              felmue @aitech
              Hello @aitech
              have you double-checked that port A actually has power? You'll need a multimeter for that and measure between black (GND) and red (5 V) wires.
                aitech @felmue
                Yes, its showing 4.83V, so should be good
                Jon
                • LuftwaffleL Offline
                  Luftwaffle @aitech
                  @aitech Dont' throw that sensor away yet.
                  There is an error in the ENV_Pro demo code:
                  Line 51 should read Wire.begin();
                  After changing that it worked fine for me.
                  The interface address for the sensor is actually defined on line 57.
                  Pretty impressive sensor.
