    Micropython on M5StickC Plus2
    Micropython
    4.9k
    • C
      citizenfishy
      Can anyone tell me which firmware to use on the M5StickC Plus 2 that supports the LCD display? I don't want to use UIFlow as it takes up too much room on the flash drive.
      I am using Thony to develop and at the moment the M5 Stack Atom image works but obviously the LCD interface doesn't.
      The M5burner software is a nightmare and I cannot get it to work reliably, it keeps giving a message "Get Configurations Failed" but adding firmware using Thony works perfectly.
      Any help appreciated.
        ajb2k3 @citizenfishy
        @citizenfishy Use the Latest ESP32 variant of Micropython for the CPlus2.If it doesn't have the driver then you will need to add the library separately.
        I think there are Circuitpython and Micropython version available now.
        • C
          citizenfishy @ajb2k3
          @ajb2k3 I can only find this one for M5Stack products:-
          https://micropython.org/download/?vendor=M5 Stack
