    OSError: [Errno 116] ETIMEDOUT
    UiFlow 2.0
    5
    2.2k
    • G
      ggong
      I have a Core 2 v1.1 running UIFlow2.0v2.0.7CORE2 Firmware and programing over UIFlow2 in Chrome. I have a PaHUB connected to the Core with a Grove cable. I keep getting the error code below even though everything is connected. It did work for about 3 hours yesterday until I unplugged the core from my computer. Now I'm getting the error again. The program hasn't changed between when it worked and when it didn't work. I've tried swapping the grove cable and that hasn't helped. How would you suggest resolving the error?
      MicroPython v1.22.0-dirty on 2024-06-06; M5STACK Core2 with ESP32(SPIRAM)
      >>> [INFO] Syncing resources...
      [WARN] WiFi not connected.
      [WARN] quit sync.
        File "main.py", line 486, in <module>
        File "main.py", line 459, in setup
        File "main.py", line 85, in Initialize_IO
        File "unit/extio2.py", line 1, in set_config_mode
        File "unit/extio2.py", line 1, in _write_u8
        File "unit/pahub.py", line 1, in writeto_mem
        File "unit/pahub.py", line 1, in select_channel
      OSError: [Errno 116] ETIMEDOUT```
      • R
        reverbrick @ggong
        @ggong Hello, did you manage to get it working?? I am pulling my hair out as all M5 products were working straight out of box.
        My setup is Atom Lite running freshly built S3 variant of micropython. I am getting ETIMEDOUT each time. Example code:
        from machine import SoftI2C, Pin
        DEFAULT_ADDR = const(0x45)
        FW_VERSION_REG = const(0xFE)
        i2c =SoftI2C(scl=Pin(1), sda=Pin(2), freq=400000
        print(i2c.readfrom_mem(DEFAULT_ADDR, FW_VERSION_REG, 1))
        I'll appreciate any help.
        DG
          felmue @reverbrick
          Hello @reverbrick
          it looks like i2c.readfrom_mem() has some issues. Below code works for me:
          myReg = bytearray(1)
          myBuf = bytearray(1)
          i2c =SoftI2C(scl=Pin(1), sda=Pin(2), freq=400000)
          #print(i2c.readfrom_mem(DEFAULT_ADDR, FW_VERSION_REG, 1))
          myReg[0] = FW_VERSION_REG
          i2c.writeto(DEFAULT_ADDR, myReg, True) # set register to read from
          i2c.readfrom_into(DEFAULT_ADDR, myBuf, True) # read FW byte
          print(myBuf)
          • R
            reverbrick @felmue
            @felmue Felix, thanks for your response.
            This indeed works.
            Trying to read/write some other registers (digital in) no luck yet, but at least there is some progress.
            Thanks again.
            • L
              laursena @reverbrick
