    Fire with UIFlow2
    M5Stack Fire
    4.5k
    • A
      a.wussow
      Hi all,
      i'm new to the M5Stack universe. I got my Fire 2.7 today and tried to upload the UIFlow2 Firmware for fire.
      Flashing is working well (i also get a success message, hash was verified, ....), but the device is dead after flashing.
      On the serial monitor i can see that something is corrupted:
      Rebooting...
      ets Jul 29 2019 12:21:46
      rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff0030,len:4912
      load:0x40078000,len:15532
      load:0x40080400,len:3696
      entry 0x400805e0
      E (1766) esp_psram: SPI SRAM memory test fail. 347/131072 writes failed, first @ 3F80B420
      E (1766) cpu_start: External RAM failed memory test!
      abort() was called at PC 0x40081ae1 on core 0
      Backtrace: 0x40082605:0x3ffe3b90 0x40098181:0x3ffe3bb0 0x4009ba71:0x3ffe3bd0 0x40081ae1:0x3ffe3c40 0x40079630:0x3ffe3c80 |<-CORRUPTED
      I also tried different version, but without any success. Is there any possibility to work with the Fire and UIFlow2?
      Thank you very much!
      Best,
      André
        ajb2k3 @a.wussow
        @a-wussow Did you use M5Burner?
        Did you erase before burning?
        Did you select the correct firmware version?
        • A
          a.wussow @ajb2k3
          @ajb2k3 Thanks for your response.
          Yes, i used M5Burner and also tried erase before burning.
          I selected "UIFlow2.0 Fire".
          But in the meantime i worked with Arduino IDE and tried it again. After flashing with Arduino, Erasing with M5 Burner and Flashing again with M5 Burner its now working. Strange ...
          Thank you.
            ajb2k3 @a.wussow
            @a-wussow Glad to see you got it working again.
