    M5Dial UART Write not sending data
    UiFlow 2.0
    • X
      xbr11332003
      The following M5Dial/UIFlow 2.0 code is able to receive data from Arduino Uno r4 wifi, but i cannot get data to Arduino. Using basic example Arduino code that works on other devices. Am i missing something? Tried every write command in UART list.
      import os, sys, io
      import M5
      from M5 import *
      from hardware import *
      label0 = None
      label1 = None
      label2 = None
      rotary = None
      uart1 = None
      def btnA_wasClicked_event(state):
        global label0, label1, label2, rotary, uart1
        rotary.reset_rotary_value()
        label0.setText(str(rotary.get_rotary_value()))
        label1.setText(str(rotary.get_rotary_value()))
        print(uart1.read(1)[0])
        uart1.write(bytes([1]))
      def btnA_wasHold_event(state):
        label1.setText(str('hold'))
        label2.setText(str('Label'))
      def setup():
        M5.begin()
        Widgets.fillScreen(0x222222)
        label0 = Widgets.Label("0", 96, 80, 1.0, 0xffa000, 0x222222, Widgets.FONTS.DejaVu72)
        label1 = Widgets.Label("label1", 88, 158, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
        label2 = Widgets.Label("label2", -21, 114, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu9)
        BtnA.setCallback(type=BtnA.CB_TYPE.WAS_CLICKED, cb=btnA_wasClicked_event)
        BtnA.setCallback(type=BtnA.CB_TYPE.WAS_HOLD, cb=btnA_wasHold_event)
        label1.setColor(0xcc33cc, 0x33ff33)
        rotary = Rotary()
        uart1 = UART(1, baudrate=9600, bits=8, parity=None, stop=1, tx=13, rx=15, txbuf=256, rxbuf=256, timeout=0, timeout_char=0, invert=0, flow=0)
      def loop():
        M5.update()
        if rotary.get_rotary_status():
      if __name__ == '__main__':
        try:
          setup()
          while True:
            loop()
          try:
            print_error_msg(e)
          except ImportError:
      Arduino Code:
      int incomingByte = 0; // for incoming serial data
        Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
      Serial1.begin(9600);
        // reply only when you receive data:
        if (Serial1.available() > 0) {
          // read the incoming byte:
          incomingByte = Serial.read();
          // say what you got:
          Serial1.print("I received: ");
          Serial1.println(incomingByte, DEC);
      • X
        xbr11332003 @xbr11332003
        @xbr11332003
        Tried every UART write command and arduino is not receiving data.
        Serial monitor on Arduino prints -1. Again, I can send data to m5dial but arduino does not receive. Other arduino boards work flawlessly. Please help felix.
          felmue @xbr11332003
          Hello @xbr11332003
          have you tried to send the data with trailing CR LF? E.g. uart1.write('hallo\r\n')? Works for me.
