    Maximum output power
    Atom
    atom s3 power supply
    3.8k
    • I
      imahgin
      Hi there,
      I've just purchased an AtomS3 and I would like to know the maximum current available from 5V and 3V3 pins.
      I'm planning to power a small sensor which requires 3V3 and need to know the max. power the AtomS3 can supply.
      There are no schematics or other relevant information available and the only references are from the Atom Lite.
      In that device a 0.5A protects the 5V pin, and a SY8089A is used to get the 3V3 which can provide up to 2A -if no limitation from the input, of course-
      Does the ATOMS3 use the same power control as the Lite one?
      Thks in advance
        ajb2k3 @imahgin
        @imahgin Yes, the only difference is that the lite lacks the screen.
        • I
          imahgin @ajb2k3
          @ajb2k3 said in Maximum output power:
          Thks Adam
