    Error Request failed. Check the network and try again!
    UIFlow
    8
    12
    7.1k
      mattjcuk @Xio1996
      @Xio1996 Exactly the same for me, everything was working this morning then all of a sudden getting the "Error Request" when trying to save.
      Kind regards,
      Matthew
        felmue @mattjcuk
        Hi guys
        same error here when I try to save my UIFlow2 blocks.
        @m5stack please fix.
        • A
          ankurjana
          Same issue, its definitely some cloud connection problem
          • Xio1996X
            Xio1996
            Just tried it this morning and it all works again.
            Thank you for fixing the problem.
            I was just being silly with my USB problem. It helps if I click on the USB device, doh!
              ajb2k3 @Xio1996
              @Xio1996 ROFL!
              I’ve been busy so wasn’t able to check on the server but because UIFlow uses Micropython, devices can be programmed offline using IDE’s like Thonny and Mu!
                makingautomation
                Hi Guys
                I'm still having this issue and have been since yesterday.
                Does anyone have a solution for this or is it an M5 server related issue?
                  felmue @makingautomation
                  Hi guys
                  for me it comes and goes. Sometimes it works, sometimes it fails.
                  BTW: browser console reports an 'internal server error' - so it's most likely a server side issue.
                  • R
                    rfok
                    Hello!
                    Same issue foe me
                      mattjcuk @felmue
                      It was working first thing this morning but not now.
                      Thanks,
                      Matthew
                        mattjcuk @mattjcuk
                        Seems to be back
                          SveinHa @mattjcuk
                          Started with UIFlow 2.0/M5Paper today and just when I got things to work, I got network error. Unable to transfer program using USB also... or the USB seems to work but the program transferred is an old version... Restarted my PC end lost quite a bit but still "Check network..."...
