    Problems with the Labels
    UIFlow
    16
    27.6k
    • G
      gadjet
      Why does setting the font size only work once for the first label in the Flow GUI and even if I try to set them in the "setup" it has no affect on the labels?
      How do I stop the labels leaving a ghost blue image on the background as they change?
        ajb2k3 @gadjet
        @gadjet said in Problems with the Labels:
        I'm getting font not defined.
        Try lcd.clear function before the lcd.print function.
        • G
          gadjet @ajb2k3
          @ajb2k3 In the UIflow if I reload the page and the project I can edit the fonts OK but then for some reason the properties when I click on the label always show the same properties, say for label0, no matter which label I'm right clicking on.
          Reload the page and it works again for a while..... is it just me?
            ajb2k3 @gadjet
            @gadjet
            I'm getting the same.
            • G
              gadjet @ajb2k3
              @ajb2k3 said in Problems with the Labels:
              @gadjet
              So it looks like it's a problem with the UiFlow interface then, is it a known bug?
                ajb2k3 @gadjet
                @gadjet
                @heybin do you know about this bug?
                • H
                  heybin
                  I have met this, but I don’t know how to reproduce it,Can you describe how to trigger?
                  ajb2k3A G 2 Replies Last reply Reply Quote 0
                    ajb2k3 @heybin
                    @heybin said in Problems with the Labels:
                    Will see If I reproduce the steps I took to cause the bug later.
                      I have added a few extra font changes to trigger the bug but its the first set font that is triggering "Font not defined."
                      alt text
                      UIFlow and firmware 1.1.1
                      • H
                        heybin
                        this bug will fix in those day, but gadjet said looks like another bug...
                          The ghosting, i think, is to do with the lcd screen,
                          I made guess that he was using the deja vue and trying to set it with the different size specific block.
                          • G
                            gadjet @ajb2k3
                            I did some more work and found the ghosting is when I modify a label, when I leave the label and then use LCD.Print to add the text is seems to be OK.
                            I was mistakenly using the label object to write a changing value to the screen, LCD.print works OK but editing the label would still give the ghosting issue.
                            • G
                              gadjet @heybin
                              I have a suspicion that it happens after the code has been downloaded and you try to edit the labels, a reload of the page and the project fixes it.
                              I will test out my theory tonight and feedback.
                              • world101W
                                world101 @gadjet
                                Where is LCD.print in UIFlow? Is it the print block under the Text menu?
                                  ajb2k3 @world101
                                  @world101 lcd.print is a micropython command, you use the Label show block which is the first block I put under the setup bock in the screen grab I posted above.
                                  • G
                                    gadjet @world101
                                    @world101 It's in the "Graphic" group
                                    ![LCD.Print](image url)
