    ImportError: no module named 'M5'
    UiFlow 2.0
    2.0k
    • B
      brendonhatcher
      I am using the Stick C Plus 2
      I used the M5Burner-v3-beta-win-x64 burner
      Downloaded UIFlow2.0 StickC Plus2 v 2.0.7
      Burnt to Stick with no error
      Using UIFlow 2.0.7 at https://uiflow2.m5stack.com/
      I connected the Stick via USB and the screen shows:
      V1.13.4
      API key
      Cloud
      I loaded a new project in UIFlow, for the correct device.
      Run > Connect
      Connected to serial port
      Run
      File "_flow.py", line 41, in <module>
      KeyboardInterrupt:
      MicroPython 9d61eff07-dirty on 2024-04-25; M5StickC-Plus2 with ESP32
      >>> import gc
      >>> gc.collect()
      === import os, sys, io
      === import M5
      === from M5 import *
      === def setup():
      ===   M5.begin()
      === def loop():
      ===   M5.update()
      ===   try:
      ===     setup()
      ===     while True:
      ===       loop()
      ===     try:
      ===       print_error_msg(e)
      ===     except ImportError:
      File "<stdin>", line 2, in <module>
      How do I resolve this?
      Brendon
      • B
        brendonhatcher @brendonhatcher
        Worked it out.
        The Stick was showing V1.13.4, which was the firmware version for UIFlow 1.
        I had previously flashed that onto the stick.
        When I was burning UIFlow 2, it didn't erase or overwrite the V1 firmware.
        I forced an erase by going to Burn / Erase.
        The stick is now showing the V2 firmware and I am able to flash new programs to it.
