    M5 Stack Fire does not boot after flashing UI Flow 2.0.6.
    4 Posts 2 Posters 1.9k Views
      pawinchan
      Hello! I am trying to flash UI Flow 2 onto my M5Stack Fire with M5Burner. The flash went successfully. However, the screen does not come on after several tries, although the "zzzz" noise can be heard when pressing the power button. Here are the logs from the serial monitor:
      ets Jun  8 2016 00:22:57
      rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff0030,len:4912
      load:0x40078000,len:15532
      load:0x40080400,len:3696
      entry 0x400805e0
             _  __ _
       _   _(_)/ _| | _____      __
      | | | | | |_| |/ _ \ \ /\ / /
      | |_| | |  _| | (_) \ V  V /
       \__,_|_|_| |_|\___/ \_/\_/  2.0.6
      E (485) spi: SPI3 already claimed by psram.
      E (485) spi: spi_bus_initialize(772): host_id already in use
      E (485) spi_master: spi_master_init_driver(204): host_id not initialized
      E (494) spi: SPI3 already claimed by psram.
      E (497) spi: spi_bus_initialize(772): host_id already in use
      E (503) spi_master: spi_master_init_driver(204): host_id not initialized
      E (524) spi: SPI3 already claimed by psram.
      E (524) spi: spi_bus_initialize(772): host_id already in use
      E (524) spi_master: spi_master_init_driver(204): host_id not initialized
      E (556) spi: SPI3 already claimed by psram.
      E (556) spi: spi_bus_initialize(772): host_id already in use
      E (556) spi_master: spi_master_init_driver(204): host_id not initialized
      E (587) spi: SPI3 already claimed by psram.
      E (587) spi: spi_bus_initialize(772): host_id already in use
      E (587) spi_master: spi_master_init_driver(204): host_id not initialized
      E (16273) wifi:Association refused temporarily, comeback time 4294967266 (TUs) too long, max allowed 5000 (TUs)
      How can I get UI Flow 2 Running on the M5 Stack Fire?
      Thanks in advance.
        ajb2k3 @pawinchan
        @pawinchan You need to erase first and use the correct uiflow2 version.
          pawinchan @ajb2k3
          Hi, Thanks a lot for your reply.
          I previously have erased and flashed this one to the M5Fire (in screenshot below). Screenshot from 2024-05-26 18-14-19.png
          Which version should I go with instead?
            ajb2k3 @pawinchan
            @pawinchan After erasing and then burning (that looks like the correct version)
            Once UIFLow say complete hard resetting, wait for a while and then press the fires power/reset button
