    CAD Files of the cases?
    FAQS
    8
    22.9k
    • B
      Buhi
      Hi there
      Where are the CAD Files to download of the cases? Would be great to have the source.
      I have searched but I didn't found
      Best regards Buhi
      • JJJ
        JJ @Buhi
        @buhi
        Hi Buhi,
        This is what's available so far.......
        https://github.com/m5stack/M5-hardware
        https://www.thingiverse.com/thing:2754642
        http://forum.m5stack.com/topic/59/diy-mini-proto-board
        • B
          Buhi
          @JimiT Thank you.
          I think that's enough for Solidworks and my 3D Printer ;-)
          • J
            jjcain1
            Buhi,
            To make compatible PCBs we need accurate dimensions for the M5stack Proto-2.54.
            The stack requires a perfect mechanical alignment to work. I am developing a plugin M5stack module
            Please provide a drawing where the hole locations and smd connector location dimensions are provided.
            Thanks.
            • m5stackM
              https://github.com/m5stack/M5-hardware/blob/master/PROTO_254.PcbDoc
              • J
                jjcain1
                Buhi,
                The 30 pin smt connector used in the M5stack has shorter pins and is different than the US commercial parts.
                What is the male connector part number. Please provide a pdf drawing of the part.
                Thanks.
                • JJJ
                  JJ @jjcain1
                  @jjcain1 Hi, I haven't seen anyone list part numbers for the headers. M5Stack seem to be the only known supplier at this time. Pin pitch is listed as 2.54 mm. Sorry I don't have a PDF drawing.
                  • m5stackM
                    the 2*15 pin connector is a custom product, only supplied by us.
