    M5Dial, no wake up with button
    30 Posts 3 Posters 26.7k Views
      Cognitive5525
      @felmue said in M5Dial, no wake up with button:
      everybody can call any of the sleep / shutdown modes as they like. I try to be consistent in writing deep or light sleep when I mean the sleep modes of the ESP32 and shutdown mode when I mean it is done via MOSFET.
      Agree and I know you are. Unfortunately M5Stack are not very consistent! They call it "sleep" when the board is shut down. Their timerSleep() function is supposed to shut down their boards with BM8563 RTC.
      I also agree the M5Dial should be able to "shutdownsleep" (new term 😜) when powered from the green power terminals (P5 ?).
      However, where does this one lead?
        Hello @Cognitive5525
        you are correct, M5Stack is not consistent and the function M5Dial.Power.timerSleep(10);, when followed down the rabbit hole, does all of the above (deep / light sleep or shutdown) depending on the core and possibilities.
        Good find. M5V is the 5V of the M5Stamp. Now we know why M5Dial stays powered on when powered from the green connector. I wonder why M5Stack thought this connection is needed as M5Stamp is already powered through 3.3V. Strange.
          HappyUser
          Thank you all for sharing your insights. I hope it offers help to others.
          For us it means back to the drawing board.
          Regards to you all.
          Btw, M5Din meter is also not an option because I recognize the same electronic scheme.
            Hello guys
            @Cognitive5525 : I think I know the reason for that 5 V connection between M5Stamp and the M5Dial board. It is required for battery charging when powered from USB. But M5Stack probably should have used a diode there to make sure power can only flow from USB to the battery charger, but not the other way round.
            BTW: as an experiment to prove the above I removed the 5 V connection between M5Stamp and M5Dial board and now I can power M5Dial from the green connector and it does a proper shutdown (same as when powered from battery) and can be woken by the wake button.
            Please note: If you go that route yourself, please be aware that I cannot be held responsible for any damage that might occur and you most likely void the warranty of your M5Dial.
              HappyUser
              Wow, I take full responsibility for my own. But how did you do that? Please elaborate.
              I assume you removed the 5volt pin of the M5Stamp. ?
                Hello @HappyUser
                correct, that is what I did. I removed the 5 V pin of the M5Stamp.
                  HappyUser
                  Final question : how did you enter sleep mode or power down?
                    Hello @HappyUser
                    please find my example here.
                      Cognitive5525 @felmue
                      Excellent! Now I'm curious : what is the current consumption on the external power input when the board is powered off or "sleeping"
                        Cognitive5525
                        I can see you import M5Dial.h is this supposed to be a part of M5Unified?
                        I use M5Unified.h in my code for my Core INKs..
                          please find my measurements here.
                          M5Dial.h includes M5Unified.h. See here.
                            Cognitive5525
                            What voltage did you use?
                            Ah OK! I see you are using a "dedicated" library for M5Dial which in term relies on the "general" M5Unified library. I found a similar "dedicated" for the CoreINK but that seem not to use M5Unified.
                            So I stick with using M5Unified "directly"..
                              above measurements have been done via battery connector @ 4.2 V.
                              If I use the green connector (and with aforementioned hardware modification) then in shutdown mode I measure about: ~ 1.5 mA @ 6 V
                              I guess the higher shutdown current (compared to when powered via battery connector) is due to the DC/DC converter converting +VIN into +5VIN and the battery charger IC which both stay powered even in shutdown mode.
                                HappyUser
                                Thanks to Felix.
                                I also tried his solution of removing the 5V pin from the M5Stamp, power down and wake up with button works perfectly. Even in combination with power timer sleep. Very low current. A big relief for us, save us a lot of time (and €) to find another solution for an unexpected behaviour. Many thanks to Felix!
                                Btw, you really have to cut the 5 volt pin short because otherwise it still makes contact.
                                  felmue @HappyUser
                                  Hello @HappyUser
                                  you are very welcome. I am glad to hear you got it working to your liking. And thank you for reporting back.
