    THERMAL UNIT (MLX 90640) does not work.
    Units
    12.8k
    • T
      tchisaka
      I have M5Stack Gray and Thermal Unit.
      I use Arduino IDE and I installed Arduino core for ESP32 using the board manager.
      I tried the example sketch that was included with M5Stack library.
      https://github.com/m5stack/M5Stack/tree/master/examples/Unit/MLX90640
      I find that the THERMAL UNIT works or not is depending on the version of the ESP32 software.
      • ESP32 v1.0.0 : not work
      • ESP32 v1.0.1-rc1 : work
      • ESP32 v1.0.1-rc2 : not work
      • ESP32 v1.0.1-rc3 : not work
      • ESP32 v1.0.1-rc4 : not work
      • ESP32 v1.0.1 : not work
      Only the v1.0.1-rc1, the Thermal Unit works. But I do not find the reason.
      I want to work the Thermal unit with lastest version of ESP32 software.
      Please give me some advice.
      • yelloweliseY
        yellowelise
        This my version (improved) can you try?
        https://github.com/yellowelise/M5Stack-Thermal-MLX90640
        • H
          heybin
          hello, change the MLX90640_I2C_Driver.cpp line 46
           if (Wire.endTransmission(false) != 7)
           to
           if (Wire.endTransmission(false) != 0)
          because in ESP32 v1.0.1-rc1, Wire.endTransmission(false) ok will return 7 not 0, in last, is different
          • T
            tchisaka @yellowelise
            @yellowelise
            Thank you !
            Using your programs, I got the data from MLX 90640.
            yelloweliseY 1 Reply Last reply Reply Quote 0
            • T
              tchisaka @heybin
              @heybin
              I fixed the code according to your advice.
              I got data from MLX 90640 with Arduino core ESP32 v1.0.1.
              Thank you !
              • yelloweliseY
                yellowelise @tchisaka
                @tchisaka
                you like the "improvement"?
                • T
                  @yellowelise
                  I was glad that I could understand why I could not get the data.
                  Thank you.
